Question about Kenmore Refrigerators
Hello, I have a Kenmore Model 253.73893302 fridge. The ice maker is not working. The model icemaker is M1. I removed the plastic cover and noticed there is an adjustment screw. What is the function of
Hello, I have a Kenmore Model 253.73893302 fridge. The ice maker is not working. The model icemaker is M1. I removed the plastic cover and noticed there is an adjustment screw. What is the function of this screw. Can it solve my problem?
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: whirlpool fridge model WF-NL300 ice
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Posted on Feb 29, 2008
aborcass
  • 2651 Answers
SOURCE: kenmore mod. 59672822200 ice
you should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Posted on Mar 13, 2008
  • 109 Answers
SOURCE: kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Posted on Mar 30, 2008
Ice maker... its makes the ice but then doesn't dispense it the whole way.. its like it gets stuck sitting there and doesn't want to keep rotating, i have to lift or "reset" the wire ... its a model # M1
Good Afternoon Sean, thanks for your inquiry!
I understand that your icemaker is not dispensing ice and it gets stuck rotating. You have provided me with a model number of M1 and I was unable to locate any information on that icemaker. May I have the model number of your refrigerator? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Mar 15, 2015 | Frigidaire Ice Maker / Icemaker 5303918277...
How do I replace the ice maker in my Sears side by side kenmore refrigerator model no 106.58142801 already have replacement ice maker just need to know how to install it and take old one out
Hello, Thank You for using FixYa. I will be helping you today.First remove the door that covers the icemaker it just pops off be careful it breaks easy. next there is one screw under the icemaker to the right side remove that screw.Now the piece that screw went through pops off.Now if you look under the ice maker,the rails that it slides into there are plastic clips you have to push up and slide the whole icemaker toward you. Thats it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Refrigerators
How to take out old ice actuator on Kenmore fridge
The easiest thing to do is remove the icemaker first. Ujnplug your fridge first, though. Take a 1/4" nut driver and remove the screw at the botton of the icemaker. Then loosen the 2 screws on the topside of the ice maker. You'll be able to see the back screw, but the front one is kinda hidden....you'll have to use your fingers for eyes on that one! Lift up on the icemaker and it should come free from the screws. Disconnect the electrical plug, being sure to release the little latch on the side of the molex plug.
Now you can work on the icemaker....there is a white plastic cover over the end of the icemaker, pull that off and you can start to see the guts of the icemaker. There are 3 phillips head screws holding the motor module on, and the rest of it can be torn down from there. Good luck!
Aug 13, 2010 | Kenmore 57029 Side by Side Refrigerator
My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Jun 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Loud noise from JD-21 ice maker
Usually a stripped gear or a bad icemaker motor. Remove the icemaker front cover by using a flat screwdriver to pry it off between the bottom of the icemaker and the cover. Inspect the icemaker to see if the large white plastic gear has any broken teeth or is cracked in the middle. The motor is in the 10:00 position of the white gear. If the gear is ok, and the noise is coming from the motor, replace the motor.
After unplugging the refrigerator you can remove the motor assembly by removing three screws in the mounting plate, and then two screws holding the motor on. The parts house also sells the complete icemaker, however your refrigerator is already 29 years old if I am reading your model number correctly. Good Luck, Appliance Specialists
Jan 01, 2010 | Kenmore Refrigerators
Side by side Whirlpool fridge with ice maker as well as ice and water dispenser in door. Dispenser works for both ice and water so water is getting to the system, but the ice maker has suddenly stopped...
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Mar 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Kitchenaid removing icemaker
on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jun 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
No water to ice maker
Hope this helps.
Apr 20, 2008 | Refrigerators
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
184 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
