Question about Boating
It will not go into reverse but will go into forward. what should i do first? 1986 mercury outboard
  • Kirstin Hicks
    Kirstin Hicks Mar 24, 2012
    excuse me i meant 4 cylinder mercury inboard
  • 5,522 Answers
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
Posted on May 23, 2009
5 Suggested Answers
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 10 Answers
SOURCE: fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Posted on Oct 25, 2009
Testimonial: "Thank you coachtheune. I appreciate your help."
  • 5522 Answers
SOURCE: when i put my mercury 150 into gear it hits really
See if you can turn down the base idle some. Then check your gear lube, sometimes you can get an airpocket and the top end is dry. Last, if still not fixed, see if you can adjust the cables so that the throttle RPM changes after the gears do.
You want a little lag in the throttle so you don't take out a dock when coming onshore.
Posted on Mar 17, 2010
  • 10 Answers
SOURCE: mercury outboard goes forward in reverse and vise
you probably solved the problem by now, but the linkage is reversible in the control console, pretty straight forward when you open it up..
Posted on Jan 03, 2011
I have a 1986 mercury outboard motor, thunderbolt ignition, 50HP, 4 cylinder. Forward gear works great. Reverse gear works very slowly , moves boat very slow and weak. Appreciate any help.TY
there is no gear box as such in an outboard leg it is just a clutch dog that is slid from front to rear to engage the cogs attached to the prop shaft
the related gear forward or reverse is attached to the shaft with a drive pin or splines
you will have to pull the unit apart to find what section has failed as it appears that the cog on the shaft is slipping ( sheared pin or failed splines in cog)
Mar 28, 2017 | Mercury Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
Mercury outboard 70 hp 1987 when in forward gear the prop turns one way when in neutrel spins both ways when in reverse the prop is locked both ways is my lower unit working property
mercury and others have a "sawtooth" cut for forward gear so the prop will rachet spin backward when dry tested, and a square clutch dog for reverse, which when it finally engages locks the prop in reverse. and will not spin in either direction.
So when you shift--- snap in in gear-- do not ease it in gear, as it will wear the dog out faster.
Sep 27, 2012 | Boating
Fuel oil mixture for 1986 mercury 115
Oct 25, 2009 | Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
Jun 07, 2009 | Boating
Boating Logo
860 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
