Question about Nikon D50 Digital Camera
Dead Nikon D50 in mint condition... Changed lenses with the power off. Powered back on and no LCD, or any actions at all. Flash will not pop up, no shutter noise, no auto focus. No top menu, no back menu. Did the double green button reset and the hard (hole in the bottom of the camera) resets while both on and off, with and without batteries, with and without SD card and every combination. Tried different lenses, also without a lens. Tried with two additional Nikon brand, fully charged batteries, and also with the AC cable. Hooked to the Mac, and no "hard drive" icon shows on the desktop. This thing is DEAD. I even took off the bottom casing and the back casing. Nothing hanging or loose. The camera was never dropped, never wet, never around static, and was being used inside a hotel room at around 68 dry degrees. Had around 12-14,000 shutter actuations. Any thoughts other than the obvious "Send it to Nikon?" It is way out of warranty. Thanks.
  • Gary Lewis
    Gary Lewis May 20, 2009
    Thanks, Trevor. My dad suggested taking it up to the local camera store and trying one of their Nikon batteries, thinking along the same lines as you.
    Because it happened "out of the blue" I had been assuming it was a failure within the camera circuitry or software.
    Fingers crossed!
Sounds like a power problem. Try checking voltage of battery and cleaning contacts with a cotton bud and electrical contact cleaner $8 at repco. Had a similar problem with a pentax mini slr. Verdigris (****) on battery terminals is dynamite in low current circuits. If you cant afford contact cleaner use special methylated spirit ( $3.00 at local pharmacy). Good luck Trevor
Posted on May 20, 2009
How do you install a flash bracket to a nikon d50?
Most flash brackets screw into the tripod socket on the base of the camera. If your doesn't, please feel free to reply to this post, giving the make and model of your bracket.
Jun 17, 2011 | Nikon D50 Digital Camera with 18-55mm and...
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikin D50 autofocus
I figured out that when changing lenses my finger must have hit the little switch and flipped it over to manual focus. I changed it back and it now works. Thanks.
Feb 20, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Flash on Nikon D50 will not latch down
If you have a fine screwdriver, remove the two screws underneath the pop up flash housing and remove the upper housing. BE VERY CAREFUL OF THE 300V at wires under the cover. You can see where the latch catches on a disk with steps - rotate the disk to a lower step and it will catch. Otherwise, an independent repair shop can probably do it while you wait for less than $40 USD.
Nov 25, 2008 | Nikon D50 Digital Camera
Nikon D50 lcd problem
I'm sure that the auction/sale has ended for this, but I'll go ahead and answer it. Yes, it could be a simple loose/broken cable. But when it comes to cameras, is that a good thing? Something had to jar that cable. Nikon builds are strong, possibly the strongest. The guy who owns that camera was probably very rough with it, and therefore MUCH more could possibly be wrong it (fractures, scratches, etc.)
I bought my d50 used, but the guy I bought it from was smart enough to take SEVERAL pictures, including that of the glass, the mirror, display, everything. I had the option of buying a d50 for $150, and all it had wrong with it was a crack going along the outside of the analog lcd and down part of the camera. Problem was, how hard did he drop it? He might have even knocked the internals around!
Save yourself headaches, and most probably expensive future investments, and be sure what you're buying is in mint condition (body scratches and general wear on rubber grips, etc. aside). Most people who own SLRs (with exceptions to some professionals) cradle their cameras like it's their baby.
Aug 19, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Changing lenses
hmm the correct way is to turn the lens to te left by pressing the release button, and keeping it pressed untill the lens is of (either turn the camera on the back, facing the NIKON brand on top , te bottom of the camera away form you and the internal flash and front lcd towards you
Jun 08, 2008 | Nikon D50 Digital Camera
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
177 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
