Question about GE 35GT740 35" TV
Need Replacement Part or Part #
Need front panel button/IR circuit board for a GE Model 35GT740
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Please contact for your parts.
hope this will help
good luck.
Andrew electronics address
In Santa Clarita, CA
www.andrewselectronics.com (800) 274-4666
Posted on Oct 17, 2007
How can I find replacement TV Parts
Check Amazon or eBay. Put in your model number or the circuit board part number. You might be able to find used ones. Good luck!
Feb 04, 2016 | JVC Televison & Video
Remote problem
check the remote by looking at it through a digital camera while pressing a button on the remote if the light is visible in the camera then the remote is working and the IR sensor board will need replacement you can get replacement IR boards and the remote from www.tvrepairworld.com
Jan 02, 2013 | Televison & Video
How to replace an ir sensor in a phillips tv model 52pfl3603d/f7
IR sensors are tough devices firts make sure that your remote control is working view its ir led light using your phone camera you should see it flashing..another test is puting it near an AM radio ,you will hear an interference when you push any key. then the crystal is all right.Replacing the IR sensor means you really have to unsolder it from the circuit board and fing a replacement..I hope its just one of those cold solder ang not the IR sensor..Good luck.
Dec 19, 2012 | Televison & Video
How to replace olevia lt37hvs ir receiver replacement
You may find this is impossible to do---the receiver if the set has buttons on front will be located there--if on same tiny circuit board as buttons you will have to TRY to find a replacement board--Good luck as this brand often NO parts are available.
While all IR receivers are similar they have different values and mountings.
I will presume you had the remote itself TESTED which will rule it in or out.
Ir receivers sometimes show no function unless remote is right up very close are bad---they also of course can fail where there is not any responses shown.
Apr 29, 2012 | Olevia LT37HVS 37 in. LCD HDTV
GE Profile Spacemaker 2.0 - black buttons on panel for vent, boost, and light broke . Any way to replace the buttons and take the panel off?
I had the same problem. The front plate is tabbed into place and removes with a flat tip screwdriver and prying in various spots to pop out the tabs. Once the front stainless plate comes off, you need to get behind the black buttons. There is a circuit board behind the buttons, which they make contact with. The problem with mine was the circuit board pushed beyond two metal tabs that keep it in place, so that the buttons were unable to make contact. I used a curved tool to pull the circuit board back forward in front of the tabs and into place. I put the front plate back on and it works like a champ.
Oct 28, 2009 | GE Profile Spacemaker Over-the-Range...
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
Replacement bulbs still do not work
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE 35GT740 35" NO SOUND
Did you try turning up the volume on the remote or front panel?
Also, try unplugging the TV from the AC outlet for about 15 seconds to make the TV do a re-set.
Beyond this, there is most likely a failure and the set will require service.
Jerry G.
Apr 10, 2008 | GE 35GT740 35" TV
35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Nov 14, 2007 | GE 35GT740 35" TV
GE 35GT740 35" TV Logo
47 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
