Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony sxrd kds-r69xbr1
Pwr light blinking red 4 times
  • DAVEYLO Feb 29, 2008
    i AM HAVING THE SAME PROBLEM. i TURN MY SONY SXRD 50 INCH KDS-R50XBR ON AND IT TURNS OFF AUTOMATICALLY AND BLINKS RED 4 TIMES. PLEASE HELP....
  • Anonymous Mar 21, 2014
    Cleaned the fans and replaced light but light still blinks after being on for a few minutes
  • 105 Answers
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
Posted on Oct 25, 2007
You need to replace 2 fans, can be ordered from sony directly for $22 & $32, but you can find the exact fans for 60% less on a google search. small fan is Nidec model: D08R-12TS1 03B, it goes for like $7.99. The larger fan is made by sony i think and has to be purchased directly from them for $22 or a distributor. so for like $30 you can replace both fans. i attempted to clean both but think they just wear out after time, despite looking new.
Posted on Mar 20, 2010
    Problem Solver:
  • 15 Answers
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sony sxrd  kds-r69xbr1 - sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
  • judygood46 Jan 16, 2009
    ALSO TURN TIMER OFF. GO TO SONY.COM AND LOOK AT TROUBLESHOOTING.
Blowing duster inside?? Can you be more specific. This is exactly our problem. We have a Sony SXRD 50" and we have red light blinking 4 times. TV will come on and we can hear it, but no picture. Picture for maybe a second and then no picture.
Gosh thanks
Kateparr@comcast.net
Posted on Mar 26, 2008
I have a sony SXRD television, and it has five blink red lights, what should I do to fix it?
99% of the time a 5 blink is your Lamp Driver (Ballast). If that does not fix, then it is either your lamp or the power board. Part# for the lamp driver is 147401221.
Apr 19, 2012 | Sony KDS-70R2000 70" SXRD TV
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
What does it mean when red light blinks 4 times on sony sxrd tv
The service manual lists 4 blinks as "Fan Stopped". Probable cause is - "Fan 1-4 power is not supplied. (AGU board) - "Fan connector is not attached securely." - :Fan caught wires or harnesses.
I had this problem recently and I was able to clean it up and get it running again.
Feb 19, 2011 | Sony KDS-R50XBR1 50" HDTV
I have a Sony Wega SXRD. First issue was the
No. Could be a bad ballast this time. That is the box that energizes the gas to produce light. Bulb has no filament.
Sep 10, 2017 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
532 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
