Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
My troy bilt 31cc leaf blower won't start. not getting fuel, have cleaned carb, check fuel lines, and injected fuel into cylinder, will crank then but cuts right off, what to do
  • 1,040 Answers
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
Posted on May 25, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Did this solve the problem?
    Jim
Your fuel line has a split/hole in it. Probably at the top where it goes over nipple to carb.
Posted on Aug 18, 2010
Won't start.no spark to plug,tb320bv
Posted on Jun 10, 2011
2 Suggested Answers
  • 736 Answers
SOURCE: troy bilt tb320bv 31cc gas blower starts and runs
inside the fuel tank you will see a flexible fuel line with a filter attached to the end ... that filter acts as a weight to position the fuel line in the lowest part of the tank no matter what postion the blower is in ... make sure the fuel line isnt broken .. also make sure the filter is still attached .. you can replace the fuel line and filter but both have to be able to handle achohol (in the gas) .. most of the older fuel lines cant and they go bad in a short time .. its actually hard to find the correct fuel line ... the size is not usually a problem but the material its made of has to say its suitable for modern gas .. most i found at local shops are the old type and wont work ..
Posted on Nov 05, 2009
I got a no start on a troy bilt 31cc leaf blower. I've replaced the carb, fuel lines, fuel filter and cleaned spark arrester. The spark plug is always dry as a bone so i know its not drawing fuel. Im at a...
See if you have spark to the plug, if not replace coil. You did everything else it should start, make sure start switch is to the on position. You replaced carb are the lines connected to the correct places and not kinked. Is your clunk clean. not much else to go wrong. Good Luck......
Sep 12, 2013 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Won't prime, the only way i start it is to remove spark plug and put fuel in cyl. I have replaced the primer bulb and line, and the fuel mixture is correct, My next step was to buy a new carb?
try to keep it running on wd-40 after you get it started and sometimes it will clean-out the carbs varnish blockage,if not remove and clean or replace the carb
May 13, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
It will run in choke gear 2 but when moved to 3 for operating speed it dies down and turns off i follow directions on blower exactly
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see day light through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Nov 29, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Troy bilt tb320bv 31cc gas blower starts and runs if it is flat on the ground but as soon as it is picked up it quits. have pulled the carb off and cleaned it. any ideas?
Nov 05, 2009 | Troy-Bilt Mtd Southwest Tb320bv...
Fuel leak after I shut off the blower and set it down.
Well, if gas is running through your engine and out the muffler, there's a lot of fuel inside the crankcase and I doubt that you would be able to start it. My thought is that there is a cracked fuel line or fuel tank, with emphasis on the fuel line. You may want to take some housing parts off to see if you can see a drop of fuel hanging on the fuel line where it may be dripping and running over to the muffler area.
Oct 31, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Will not continue to run after relasing choke, no
you have a fuel starvation (lean condition) issue
fuel system needs cleaning
fuel lines
filter
carburetor cleaning and replace gaskets/diaphragms
Sep 28, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
2,006 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
