I have a Sabre T.V. The display button keeps comming up press menu leaves but comes back Changed the batt.in remote, still going on IM at wits end HELP!!=)
  • kierbonnie May 18, 2009
    What the Hell is the no touch button and where is it?
    Sergeant:
    Champion:
  • 255 Answers
Try opening abd cleaning your remote first.especially if the batteries leaked.it may cause damage to your remote(i hope not).clean it with alcohol and soft cloth.let dry before reassembling it.now if the problem is still there and your not using your remote,you need to call a tech to have it troubleshoot mano y mano.but if your using your remote, and the problem comes up after cleaning it.you'll need to by a new remote.it's either a universal remote or same as your remote.
Posted on May 18, 2009
  • 19,396 Answers
Try first leaving the TV unplugged for a couple of hours, that will reset internal circuit and may fix the problem.
If unplugging does not help, check that no touch button is stuck.
If still no luck, then either one of the touch button switches is stuck, or the ir sensor is faulty.
In that case contact Sabre to get parts and suppost, see Sabre Technical Services - Contact Information
Posted on May 17, 2009
What is the code of jvc tv
Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Mar 02, 2012 | JVC Televison & Video
I need to get into the service mode for this television please.
Hello
Try this.
Feb 21, 2011 | JVC AV32F476 32" TV
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
I have no manual and I need to set the time on a kenwood kdc-mp205 stereo
press the "SRC" button repeatedly to select the standby mode. "ALL OFF"
Press the MENU button for at least one second.MENU is displayed and the menu is turned on.
Keep pressing FM button until the SET CLOCK appears in the display.
Press the FWD button for at least two seconds to enter the time adjustment.
Adjusting the hours,press the FM button to advance the hours,or the AM button to make the hours go back.
Adjusting the minutes,press the FWD button to advance the minutes or press the RWD button to make the minutes go back.
Press the MENU button to end the menu mode.
and BINGO.
Mar 23, 2009 | Kenwood KDC-MP205 CD Player
I have a region 2 samsung dvd r155 and i changed to a multi-region, now wont play any dvd's
HI,
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Aug 07, 2008 | Televison & Video
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Bluetooth Icon not working
I had the same problem with my nokia n80.
The solution i found is:
with the remote go to bluetooth phone. then on the remoete av menu. now you can select bluetooth as it's not grey anymore. i would advise search device with a new pin and not the standard 0000.
Good luck.
Let me know if it worked. It did for me. (eu model)
Sep 23, 2007 | JVC KD-AVX33 Car Video Player
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Televison & Video Logo
Top Televison & Video Experts
