Frigidaire FAA065M7A Air Conditioner
Problem for Frigidaire FAA065M7A Air Conditioner
Temperature setting won't go past 32
By shonapate on May 17, 2009
Today our frigidaire window unit blinked on and off a few times then when it did come back on we couldn't set the air conditioning past 32 degrees. The air is working and the display is showing but when we try to set it to 70 degrees it will go up until 32 and then it just stops.
Clarification Request
Posted by ASK HANK on May 17, 2009
Sounds like some how it switched to ^C.
Solution #1
posted on May 18, 2009
Somewhat Helpful)
heatman1976
Rank: Master
Rating: 81%, 7 votes
There is probably a setting between farenheit and celcius. Is it set to Celcius? look in the owners manual to see how to change it to what you need. sorry I can't be of much more help on a window shaker.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FAA065M7A Air
Questions and Unsolved Problems for Frigidaire FAA065M7A Air
Do you recommend Frigidaire FAA065M7A Air Conditioner?
Answer
Answer
blower moter turns off after a hour or so some times can run all day or turn off within a hour or so... (More)
Answer
my stove shuts off 2 minute after I turn it on there's a black wire to the left when you look at the... (More)
Answer
Need a wiring schematic for a Frigidaire FAA051N7A1 Air Conditioner. The unit fell out the back side... (More)
Answer
york mini split 07-21 this unit has power,but will not come on with the remote or manualy. when the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAA065M7A Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
