Question about Eagle Intellimap 640c Marine GPS GPS Receiver
Eagle 640c Fish Finder dosen't read corectly.
Start up normal, when on auto depth range and sensitivity gives me a normal picture as I move from shallow to deeper water. Once over 50 to 80 feet of water the unit flashes the last depth and changes to 0 - 5 ft range and shows no top or bottom. Once back to shallow water comes back into the proper range. Temp and all Radar functions work normal.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
Posted on Jul 22, 2009
  • mamahound Sep 23, 2011
    Installed new transducer did not change the blinking
SOURCE:
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
The depth reads 98 to 100 feet.
I need more details about the problem you are having to be able to help you.
My best guess is that your unit will only disply data between 98 and 100 feet?
If thats the case check the range setting on your unit. It may be set to only display that range. You can set it to auto and it will automatically adjust the range from zero to just over the maximum depth it is currently reading.
May 23, 2011 | Humminbird PiranhaMax 190C Fish Finder ()
Where can i purchase a manual for a eagle fish elite 640c fish finder
Go to http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Fill in the numbers in the box number 2 below where it says to enter your email address. (There's no need to enter your email address)
Click "Download Now"
Dec 04, 2010 | Lexerd - Eagle SeaFinder 640C DF TrueVue...
Know anyone that will rerpair an Eagle Fish finder ID 6300?
I dont know what state your in but in minnesota call Fish Lectronics at 281-963-4375. or Lakesonic at 507-281-4445. Call if you need more
Apr 19, 2010 | Eagle Fishmark 320 Portable Fishfinder
Eagle Cuda 168 has no display over 30 feet of water
Try good alakaline batterys(duracell or energizer)alot of those rechargables dont hold amperage and dont stay recharged long!!!! :)
Jul 05, 2009 | Eagle Cuda 242 Portable Fishfinder
Erratic depth and does not indiacte any fish
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to sensitivity set to manual then go up one on the menu and set it to 95 – 97 this will clear up the rapid change now set zoom to manual. Your back and running.
Mar 31, 2009 | Eagle Cuda 242 Portable Fishfinder
Eagle Intellimap 640c Marine GPS GPS Receiver Logo
436 people viewed this question
Top Eagle GPS Experts
fordexpert
Sheldon Dedek
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
