Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Lawnboy 10685 mower surging problems
I have a lawnboy 10685 mower about 4 years old. It began to surge last fall and I had it rebuilt by a shop during the winter and the problem continues. It surges, then I stop it when the bag is full and it will not restart for awhile. It appears to be overheating. I took it back to the shop and they pulled the screw in gas jet on the side and said it was plugged, apparently from mowing in a dusty area. They blew it out and and it worked for about 15 minutes and will not correct itself, even when I take out the jet and blow it out. The air cleaner, spark plug are ok and the oil is fresh and full.
  • Jim Parker
    Jim Parker May 11, 2010
    Did you have anything done to the carburetor?
    Jim
  • 203 Answers
I hope that the shop didn't rebuild the whole mower engine for you if you took it in for a surge. If you mean they rebuilt the carburetor, that's what it needed. I'd call them, tell them it's doing the same thing as it was before (starving for gas, causing the governor to "hunt"). The carburetor is dirty inside. You have a blocked/partially blocked jet. You can either take the carb off yourself and try to clean it, or take it back to them and let them try again.
Here is a thought. First, before you take it back to the shop, take the small bolt on the bottom of the carb. This holds on the bowl. You do not want to take this off if the machine is full of gas, cause it will leak all over your mower/floor. Tilt the mower backwards or try to drain the gas out. When you get this little brass bolt/nut out, and get the gas cleaned up that leaked out, if you look real hard you will see a very tiny little hole in the shaft of this little bolt. Some even had 3 of them. It may appear to be just a blemish in the finish, but it has to be clean to allow proper operation. Spray with carb cleaner, and take a small wire, such as a single strand of a speaker wire or something similar. Clean that hole/holes out. Clean out the inside of the bolt shaft as well, as debris will settle in there. Put the bolt back in and tighten the bowl up. Make sure the bowl is straight and the gasket is back on the little brass bolt. Tighten snuggly, but not forced.
Try that. If it works, and the mower runs better, put some carb cleaner in the gas and run a bit.
Posted on Jan 26, 2010
  • dbogaards Aug 15, 2011
    I have a 10550 gold series Lawn boy that ran fine for 8 years then it started surging, it also started leaving a puddle under it after it sat all week, and became hard to start, I had to push the primer bulb more times than usual, and had to run with the choke partially on for awhile to keep it running, I read several references to increasing the jet size, but it used to run great, why would the jet size need increased after 8 years of great service, so, I finally assumed that the lower crankshaft seal must be leaking, allowing more air to get into the crankcase so it would rev and then the governor would slow it back down(surge) , this would also explain the puddle on the floor(excess fuel would leak out of the crankcase while it sat idle), after changing the seal, the surge problem is gone, the puddle is gone, and it starts very easy again with little to no choke and only 2 pumps pn the primer bulb when cold, I hope this helps someone else!!
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have a lawnboy 10685,changed spark plug,air filter,just had carb rebuilt and still only runs for a short time the dies, what could be the problem
you need to find out whether it is a fuel or ignition problem, I might suggest that when it quits pull spark plug and ground it to head and pull the rope like you are starting and see if you have spark, if no spark, then I would say your coil is bad, once it gets warm, it quits.....good luck
Aug 25, 2011 | Garden
Lawnmower throttles up and down
locate the carberator the unscrew the 1/2' bolt under the float bowl to remove the bowl empty and clean out the bowl reinstall making sure the o-ring is centered for the bowl it acts as a sealing ring for the bowl screw the bolt back in and tighten, this should solve the surging problem.
Sep 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Silver series 6.5 hp surging
  1. Carburetor is dirty.
  2. Air leak in carburetor or intake manifold (e.g., bad O-ring, gasket, primer).
  3. Carburetor is improperly adjusted
These are some of the more typical reasons that can cause a small engine to surge.
Jul 09, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
2,670 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
