Question about Honeywell Programmable Thermostat Heater
Batteries only last 2 maybe three days at a time.
Each time I put batteries in the thermastat they last 2 to 3 days at a time.
  • Honeywell Expert
  • 252 Answers
There is nothing in the thermostat that should use anywhere near that much power. If there is a short the batteries should be getting very warm. (try a new set of batteries and feel them about an hour after you put them in) The most likely, cheapest, and easiest thing to do next is replace the thermostat. Otherwise you should be having problems with your furnace too. Be sure to turn off the electric to your furnace before replacing the thermostat!
Posted on May 17, 2009
When I turn my cell phone off. It says goodbye. 3 days later I go to use my Camera and my phone is dead. Does the battery need to be charged on a daily basis?? What am i doing wrong? TY
Although you have turned your phone off, it is still using a small amount of power to run the internal clock & the alarm which works even if your phone is off, when u turn it off for a short time you wouldn't notice a drop in battery power, but you turned it off for 3 days, as the battery would only normally last a day or so it has drained naturally over 3 days it may also be that the battery is showing signs of dying as well, make sure it is at full power when you turn it off & plug it into your charger for a hour or so every day, you can get a new battery for it from ebay, they are not expensive, & try that, compare the times they both last.
Feb 23, 2015 | Nokia Lumia 520 Windows Phone Black
I have a 2004 deville my battery run down over night
IF THEY CHECKED FOR A DRAW ON THE BATTERY AND THERE WAS NONE DID THEY CHECK ALTERNATOR OUTPUT? IF IT WAS IN SPECS THEN YOU MOST LIKELY HAVE A BAD BATTERY. YOU MAY WANT TO HAVE IT CHECKED AGAIN. THE DEALER IS NOT ABOVE MAKING MISTAKES
Dec 08, 2014 | Cadillac DeVille Cars & Trucks
What's wrong with a infinity i30 when it has a
2 possible solutions. 1 or more serpanteen belts are not engaging ( slipping will smoke like he'll! I burnt all 3 when I started my j30 '96 after almost 2 years! Had to charge the battery overnight..everyone really should have one! Times like that you are gladjya did! And my battery was replaced the day I stopped driving it!). Either that...clogged fuel filter. Seriously, it happened in all three j30's I have owned, and one Jaguar XJ6 with saddle back gas tanks. $55 usually to change...maybe a lil' more depending the garage hrly rates.
Mar 29, 2012 | 1997 Infiniti.5 J30
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
How do I get my batteries to last longer in my GE X5? It goes through four batteries in matter of mins. I have put 12 batteries in my camera w/in 3 days and I havent even taken but maybe 20 pics in those 3...
My mother-in-law said this exact thing to me last week about her camera. I can't understand why it's running the batteries down so quickly unless the power is being left on constantly. But I can tell you regular batteries don't last long in any high tech devices anymore.
I highly recommend Lithium batteries (I prefer Energizer, but any brand will do). They tend to last at least 6 months in my digital camera. They're more expensive, so I understand most people are hesitant about buying them, but considering the number of regular batteries you'd use up in that time period, you come out better in the long run (plus you don't have to haul around tons of replacements).
If your camera runs the Lithum battery down quickly, too, I might be inclined to say that something about the camera is defective and you should call the manufacturer.
Dec 03, 2010 | GE X5 Digital Camera
Cooling system
these are somethings that maybe causing it to over heat (1) not enough cooling in it.(2) water pump drivebelt (3) Radiator core blocked (4) Bad thermostat (5) fan blades broken or cracked (6)Radiator cap need to be replace (7) Ignition timing incorrect if all fails stop by your local library and get your hands on a Haynes auto repair Manual for your car wish you the best of luck Michigan Man
Dec 09, 2009 | 1995 Mercury Cougar
Thermostat
Heat pump Thermastats have Terminals RYW/OW2 G C. I run into this a lot with people buying tStats at home depot. To wire three sages of heat you must have correct tstat. one stage cool and three stage heat. You have to have enough wires at the Tstat. I use white first stage brown second and grey or black third. Make a diagram where each wire goes. Remember to trun of air handler power or you will short the transformer or blow low voltage fuse. Yellow cool, green fan, most of the time blue is c unless it is a battery tstat. orange is O. Red R ot power wire. Rusty
Jun 03, 2009 | Heating & Cooling
Apple ipod Gen 3 short battery life
Replace the battery.  Here's the link:
fastmac.com/downloads/install3withadd.pdf
Nov 01, 2007 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Heating & Cooling Logo
87 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
