Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer shakes and producing loud noise
I have a kenmore he3t washer. Recently, i've been having a problem with its spin function. When I use the spin function, the machine begins to shake violently, producing very loud noise. Could any of you please tell me what is wrong with the washer and what can i do to fix it.
Thank you sooo much for your help!
  • cobra61 May 21, 2009
    During the spin cycle the tube shakes to the front and back causing the tube to touch the front and make noise. Feels like the suspension is loose.
    Problem Solver:
  • 8 Answers
I would start with leveling it with a level. This should be easy to do. There are four post underneath that can be adjusted.
Posted on Jun 03, 2009
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
Loud shaking in the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore elite washer has a very loud banging noise when it spins
U will need to remove the washer drum and check the washer drum stablizers and the washer drum bearing, do this to see what is wrong and how far u need to go in this repair.First open the door and spin the inner tub to make sure the tub spins freely, if not you have big problems.
If it does then remove the lower front panel. There are 3 screws along the very bottom of this panel that you can remove and then the panel will come off. Check to make sure the shocks are not cracked or broken under the tub. If not and the unit just recently started shaking a lot, then replace the shocks as they are probably worn out. If it's been shaking since the day you've gotten it and it just seems to have gotten a little worse, then purchase Shake Away pads which are specifically designed for front load washers to sit under the feet of the washer and reduce vibration dramatically.
May 07, 2010 | Washing Machines
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
288 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
