Cable VHF/UHF Receptor Needs Replaced
On the back panel of the TV is the plugin receptors for Ant-A and Ant-B VHF/UHF . Apparently they have gone bad. It is where I plug in the cable.I would like to be able to replace if I could get some direction. I don't know what the part is called or how to replace.My reason for believing it bad is because when I switch to a DVD player, it works fine and I get a good picture. So it's not the tube. When I try cable, I just get ''snow''. I can provide a picture if helpful, but I don't see that option here.
The TV is an oldie: Mitsubshi CH-3526R. But it has been flwless for 15+ years
      salt56
      • 373 Answers
      SOURCE: no receipt of signal or antenae
      Since it has voice or sound then I don't suspect the tuner but probably the tuner does not have the 33 volts that goes through r106 location number on the board. It is a 27K resistor and can be bought for about a dollar at Radio Shack. (pack of 2or3) A repairman or someone experienced in electronic soldering and desoldering can change it easily. Could cost around $50 to repair depending on the serviceman. If it has rca jacks (red, white and yellow) The tuner can be bypassed if you have a cable box that passed these signals: audio left and right and video. Hope this helps
      Posted on Dec 30, 2007
      • 9 Answers
      SOURCE: No cable
      try going into the menu of the tv and changing the tuner type from ANT to Cable
      Posted on Jan 28, 2008
      • 4 Answers
      SOURCE: Coax receptor broken! Want to replace part.
      if you truly need to replace the part then go out to a tv/mechanism store and buy the 12 in receptor to replace.
      Posted on Mar 12, 2009
      konzzz
      • 255 Answers
      SOURCE: just bought a mitsubishi cs40503 i got the dvd
      check if your unit is cable compatible.if not , you need to buy a cable converter.much better if your cable converter has audio/video out.
      Posted on May 18, 2009
      • 29 Answers
      SOURCE: have a 1995 magnavox tv got a hdtv attenna for it
      you need the cable box that the gov. was selling
      Posted on Aug 20, 2009
      I cannot set up my tv, after it had cable. when i try the setup program the tv will not accept any channels and sap appears on the screen. i want go back to uhf/vhf, can somebody help me.
      If you are in the US, there is no logical reason to go back to UHF/VHF as there are no broadcasting stations using the analog frequencies anymore. Those old tuners will not decode anything that is coming over the airwaves. Thus their channel scans will not detect ant channels, making you think there is something wrong. You would need one of the digital converter boxes sold during the transition period and then you will only get your local channels, much as you would have before.
      Oct 03, 2016 | Televison & Video
      CANT TUNE IN
      You must connect an Antenna to use the AutoTune. A set of rabit-ears is sufficient for most areas: RE: the Digital (Free) TV singals are using the old UHF/VHF frequencies - so any antenna designed for Broadcast TV should work. Connect your antenna to the ANT/Cable connection then re-run the Auto-Tune again.
      Jan 10, 2015 | Televison & Video
      How do i set the 2632 from cable to uhf/vhf antanna
      Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
      Nov 26, 2010 | Polaroid FLM-2632 Television
      Air-ant. get lower sig. but not higher than 25, 31, 47, etc.
      If your antenna is a VHF , the rest of those channels wont come in.
      You need a UHF antenna or a combo UHF / VHF
      Oct 04, 2010 | Sanyo DP19648 19 in. LCD TV
      VHF channels come in however UHF channels are not
      uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
      Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
      Mar 12, 2009 | Zenith A19A11D 19" TV
      Slot where cable fits in - Broke
      I am assuming that what you are referring to as "metal block" is the tuner assy. and that the "slot/cable receptor" is the chassis mounted 75ohm TV "F" Coax Connector (female). This is easily replaced and the component should be readily available from most electronics part stores.
      To perform a DIY and replace this, the TV has to be opened, the metal cover of the tuner pried open, and the F connector replaced and eventually soldered in place.
      Incidentally, a nice tutorial on how to go about this is posted here.
      Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
      Good luck and kind regards.
      Thank you for using FixYa.
      May 07, 2008 | Samsung TXG2547 25" TV
      No cable
      Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
      Televison & Video Logo
      93 people viewed this question
      Top Televison & Video Experts
      Electro Med Services...
