Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 error code 15,004.45:119696
In searching I got info that it might by the halogen bulbs, but I noticed another posting which related to the haolgens but the last series of numbers (119696) are different. What tools do I need and how difficult is it to do yourself?
  • iciassociate May 17, 2009
    Yes, I would appreciate having the written instructions
    President:
  • 2,072 Answers
If you take your time, Its not really hard, Just time consuming. I can send you written instructions.
Posted on May 17, 2009
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error 15,004.45:102501
Yes, that is a common problem, and not real hard to fix, but takes probably an hour to an hour and a half to repair. For someone that has never done it before that is.
First what the code means. That is a failure of the drum to heat up. The drum heaters are simply 2,, 150 watt Halogen lamps, mounted in a reflective heater. One or both of those bulbs has burned out.
The way you can tell is, turn the lights off in the room or office the machine is located. Then. looking on the right side cover, there are fan vents, opening up into the machine. Turn the machine on, and wait a minute or two, then look in that fan slot and see if you see a glowing in the machine. You won't. But that is how you know those lamps are not coming on.
You will want to replace both bulbs since you are taking that assembly out. I strongly suggest the Sylvania Halogens that are rated for 130 volts and are vibration protected. You can get them at Lowes or Home Depot, anywhere that sells Halogen lamps. You dont have to get the Sylvania ones, but they sure are the best if you can get them. The cost to fix it yourself is less than $20.
If you want, E-mail me at rak458@aol.com and I will send you the instructions on the repair. I dont have the manual. I will type it out step by step. Makes it easier I think.
May 19, 2009 | Xerox Phaser 8200 Laser Printer
Error Code: 15.004.45:113654
That code means the drum heaters are not working.
The good news is, yes you can fix it yourself.
The drum heaters are 2, 150 watt halogen lamps. One or both of them have blown out. If you want drop me an E-mail at rak458@aol.com
I will send you instructions how to replace them.
It would take 1 to 1 1/2 hours if you have never done it before. Lowes, Home Depot or any place that sells halogen lamps would have them.
I however, do highly recommend, if you can find them. Sylvania halogen lamps rated for 130 volts and have vibration protection. They cost slightly more, but well worth it. Besides even if you get those, you have less than $15 in the repair.
Let me know, I will send you the info. That's all your problem is.
May 06, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error code 15.004.45:30201
The drum heaters are bad. There are 2 ,,,, 150 watt halogen lamps that warm the drum. One or both of them are bad.
If you want the directions let me know.
Feb 19, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
Xerox Phaser 8200 Laser Printer Logo
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
