Color is not correct i need to know how to mix the colors to get the right look
  • 2 more comments
  • uzziyah May 17, 2009
    51 Inch Phillips Maganavox Projection TV, Model 7P4830 W101... my problem has nothing to do with schematics... I need advice on how to mix the colors (Red, Blue, Green) to make the picture appear balanced instead of a picture with too much Blue or Orange... Please help!!
    51 Inch Phillips Maganavox Projection TV, Model 7P4830 W101... my problem has nothing to do with schematics... I need help adjusting/mixing the colors (Blue, Red, Green) so that the picture apprears realistic... Please Help!!!
    Thanks... but that is what i was saying, i know where to adjust the colors.. But what is the mix? "How do I know how much of each color to adjust for? Can anyone help me?
    Sergeant:
    Champion:
  • 240 Answers
You need to adjust the color adjustment on the back of the unit..
called X and Y adjustments..coil..to adjust the combination of the colors...
Posted on May 17, 2009
  • 10,594 Answers
I think you have rear projection TV that got convergence failure problem and gives you 3D type picture. Thats what I got from your one line problem.
Please intimate exact model and brand of TV to check its schematics for possible reason of problem and provide you its solution. Without model and brand info, no one can assume what TV do you have.
Thanks.
  • Shahid Electronics
    Shahid Electronics May 17, 2009
    Very good, you rejected me instead of reply. Now I'm unable to assist you any more due to website system.
    Good luck.
I HAVE CHANGED THE CARTRIDGES, BUT NOW THE FACES ARE GREEN HAVE I MIXED THE CARTRIDGES UP?
look carefully at where the color cartridges go in and there is a small color band for the correct cartridge position
as each cartridge is colored , just match the colors and it will be right
Oct 19, 2015 | Epson Workforce 520 Printer
Mixing color with double developer, will it go lighter
you need color correction use a blue based tone to correct the orange. tone. ( do not do this if u have bleached your hair)
Oct 30, 2014 | Joico VeroColor Permanent Hair Color 9B...
My le pan II background color changed to a mixed red - is the display going out?
Sounds like an app changed your wallpaper settings. Try this: go to settings then click display, you will see what wallpaper you have on th list right. Touch wallpaper and choose whatever you want then click set. This may bring everything into focus with the background you need for the correct page. It seems sometimes the LePan changes color but it is actually the wallpaper somehow taking over. Let me know if changing wallpapers works to "right" the situation. I hope this helps
Apr 09, 2014 | Le Pan II 9.7" Tablet PC
How should I mix acrylic paints correctly?
You must work fast while you are mixing acrylic paint colors because the dry very fast. my suggestion is to mix your acrylics to the colors you want while using more than you need. The remaining color should be stored in a sealed container to use later.
Feb 03, 2013 | Crafts & Hobbies
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
Colors do not print right. We have tried to align, calibrate, and clean the heads, and the colors went from too much purple, to too much magenta
This would need a print head replacement kit there around $40 bucks from the mnaufacture. The issue here is the mix of the colors and this is caused by the print head.
Thanks I know this will help if you follow threw please do leave ratings and feedback
May 10, 2010 | HP Photosmart 3310 Printer
What color antifreeze
Most manufs. do NOT recommend mixing Dexcool[your "Orange" coolant] and the older "Green" antifreeze unless it's an emergency. They're not really made of the same chemicals,and don't 'play' well together long term inside an engine. I've seen the pre-mixed coolant for sale, claiming a "universal" mixing ability with ANY type coolant. But, if it's my wallet and MY time involved, I'd track down the right/correct coolant your engine.
Jun 11, 2009 | 2001 Chevrolet Malibu
I am printing pictures on my Epson Pm260. The hair on all the pictures is coming out orange and ugly. What is wrong and how can I fix it?
Sounds like you are using a single COLOR Cartridge in your printer. If so one of the colors has run out and it needs that color to mix with the othe colors to produce the right hair color. Replace the color ink cartridge and it should work right again. Bud
Dec 06, 2008 | Office Equipment & Supplies
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
