Question about Smeg 24 in. SER60S Gas Cooktop
Where is the natral gas regulator located on the smeg cooktop
I acquired this secondhand and can not see the regulator is it inside the enclosed portion or should i be able to see it
    President:
  • 1,136 Answers
Hi, you should be able to see it. Get me a mosel # and I can look this up and give you exact location.
Vic
Posted on May 17, 2009
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
New cooktop ! long flame yellow tips black deposits on pans
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Nov 03, 2013 | Smeg 23 in. SE64 Gas Cooktop
Smeg gas cooktop is continually clicking.....going mad,,,,,
Ist unplug the unit. What you have is the stovetops valve switch defective. Sometimes this will happen after a boil over. The switches get wet and temparaly short. When they dry out it should work properly.http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | Smeg 23 in. SE64 Gas Cooktop
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
In this model of gas cooktop is the gas regulator inside the cooktop or outside? I got a open box deal without the gas reg. and wonder if it is inside or if I have to order one?
On most cooktops the regulator is installed externally and is not includes... if it is there it will be right on the pipe that you hook the gas too...
heatman101
Nov 12, 2009 | KitchenAid KGCC766RSS Stainless Steel Gas...
The gas keeps cutting out of my SRV532X. Fuel is LPG Can you help
You probably have a bad gas regulator. Have a service repair technician replace it. Good luck!
Nov 07, 2009 | Smeg 20 in. SRV532X Gas Cooktop
SMEG gas cooktops quality CIR597X in particular
yes is ok the brand..but if u nid same quality but cheaper price get other brand like indesit,ariston,or glemgas.also have an nardi,jollynix ignis..check all the item u want to buy then compare wat diiferent of all..sometimes different brandbut same quality also same part inside.
tnx gerbee
Sep 13, 2009 | Cooktops
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Aug 21, 2009 | Smeg HB96CSS Gas Cooktop
Smeg 24 in. SER60S Gas Cooktop Logo
161 people viewed this question
Top Smeg Cooktops Experts
freddyfox
Timllfixit
ray gallant
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
