Question about Samsung LN-S4041D 40 in. LCD HDTV
I've cleared the scrambled channels on my samsung hdtv but how can I get them back?
    President:
  • Samsung Master
  • 1,779 Answers
Just do the initial set up again to program channels.
Posted on May 17, 2009
The info states this TV has an HDTV tuner (ATSC), however I am unable to tune any digital channels which are broadcast via our cable provider (not offered on whole number channels, rather decimel points...
You need to reset you tv to factory mode, by pressing tv off---mute 182 power---go to options and look for *reset to factory* them wait until the process is done.
Dec 19, 2010 | Samsung HL-S4266W 42" HDTV
StarView SV211K 2-port KVM Switch: alot of my channels say scrambled i ve put code in...
you have to turn the emu on when you put the codes in it turns the emu off so you have to turn it back on
May 18, 2010 | StarTech.com StarView SV211K 2-port KVM...
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Samsung HP-T4264 will not autoprogram, locks up on deleting scrambled channels
Reset to factory specifications by turning tv on, and then using the remote, hit power off, mute key, 1, 8, 2, and power on. Interval between key strokes is less than 3 seconds. When tv comes back on it shows Service Mode Display, key up to reset and press enter. Was able to autoprogram without any problems.
Oct 14, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Samsung LN-S4041D 40 in. LCD HDTV Logo
255 people viewed this question
Jerry Greenberg
Jerry Greenberg
