Question about Microvision Inc Car Audio & Video
I have two MicroVision MTV-7SIR headrest displays that only show movies in black and white. I tried multiple color video sources and all of them are in black and white. I think the problem is in the wires connecting the video source to the video displays. Can I get replacement cables?
  • 47 Answers
SOURCE: 10.4 inch headrest lcd monitors
MOST OF ALL VIDEO OUTPUTS AR NOT STRONG I SUGGEST
ADD A VIDEO AMPLIFIER
Posted on May 13, 2008
Benimur
  • 6966 Answers
SOURCE: monochrome s video
as a follow up on our online session....
It may not be an s video connection problem. it may be that your DVD (or video source) is set to a different color system other than what your projector is set to.
In your DVD, try pressing the NTSC/PAL button.
Good luck and kind regards.
Posted on Oct 21, 2007
  • 216 Answers
SOURCE: wiring problem I NEED HELP!!!!
You can fix it yourself.
atdlee@netzero.com
Posted on Mar 08, 2008
  • 149 Answers
SOURCE: Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
Posted on May 10, 2008
ButtFuzz
  • 463 Answers
SOURCE: Viore pdp42v18ha problem - no audio
Take it back to the dealer from which you purchased, receipt in hand and raise a stink.
Posted on Mar 04, 2009
Want to watch movies
Looks like it only plays .mtv files, so a converter may be needed before uploading video files to the 610.
Try these links for converters, info, etc.:
http://www.imageconverterplus.com/help-center/about-icp/supported-formats/mtv/
http://www.openwith.org/file-extensions/mtv
http://www.sharpened.net/extensions/file/mtv
Product Description: Coby MP6104GBLK MP6104G 4GB Color Display Flash MP3 Player Radio.
1.8 inch color LCD display.
Integrated flash memory.
Plays music, video, photos, and text.
Integrated FM radio.
ID3 and LRC support for song and lyric information display.
USB 2.0 Hi-Speed for fast file transfers.
Integrated rechargeable battery.
Color: Black.
Memory Capacity: 4GB.
Display Type: 1.8 inch TFT LCD.
Display Resolution: 128 x 160.
Media Support: Integrated Flash.
Format Support: Audio: MP3, WMA; Video: MTV; Photo: JPG; Text: TXT.
OS Support: Windows Vista/XP/2000.
Menu Language Support: English, Spanish, French, Portuguese, Italian, German.
Additional Functions: FM Tuner.
Audio Output: 3.5mm Headphone.
PC Interface: USB 2.0 Hi-Speed.
Power: Integrated Rechargeable Lithium Polymer Battery.
Battery Life: Capacity: 350mAh; Audio Play Time: 8hr.
Unit Dimension (WHD): 1.65 x 3.66 x 0.38 inch.
Helpful?
Mar 23, 2011 | Coby MP-610 MP3 Player
My dvd's play in black & white. cant get any color in pitures.
There are three types of display settings. 1 PAL, 2, NTSC and 3, Auto.
The pal and auto makes a display show color while the NTSC allow a display show in black and white but sometimes NTSC also shows color. It is possible that the display format on the movie is NTSC.
To fix this problem, play the movie that shows black and white. When the movie shows in black and white, press PAL/NTSC or P/N on the remote control and it should display in color.
Or Go to the player menu, check video or display setting, change it to Auto.
Problem should be fixed because that's where it lies....
But if it doesn't solve the problem, please let me know so that I may direct you further on what next to do.
I hope you understand the above.
Good luck.
Mar 04, 2011 | Philips Audio Players & Recorders
I own a toshiba 19dv500 and am having trouble viewing a dvd, the system is working but only in black and white, no colour\???
Hello there,
A black and white picture is most often due to a faulty or incorrect RGB (red/green/blue) connection or cable.
If you are using a composite connection (red/white/yellow RCA jacks), you have probably connected the yellow plug to a socket labelled Pr/Pb, Cr/Cb, or Y - on either the DVD player or the TV - most probably the TV. The yellow needs to be connected to a socket labelled "VIDEO". If you connect this to any socket labelled Pr/Pb, Cr/Cb, or Y, you will get a black and white picture.
If you are using a component connection (red/green/blue RCA jacks), one of the plugs is either not fully inserted into the socket or is in the wrong socket. If you remove any one of the R/G/B plugs, you will get a black and white picture.
If you are using a SCART cable (UK / AUS), you may have a bent, damaged or disconnected pin.
I suggest you check and correct the connections between your DVD player and TV. If you are unable to locate the problem, please try another cable as the one you are using may be damaged. If you are still unable to locate the fault, please let me know the brand and model number of the DVD player and how it is connected to the TV. If required, I can also draw a diagram showing the correct connections.
It would also be useful to know whether this "fault" suddenly occured, or whether you have just connected the player to the TV.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Mar 03, 2011 | Toshiba Televison & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
FOR POPER POWER SOURCE
power source is 11 to 12dc volts and 12oo,Ma.. thanks...
Jul 05, 2008 | MT&V Dual 7" Headrest Monitors & DVD...
No Color
sorry the problem is internal the color ic needs to be change,contact your tv repair technician
Jul 24, 2006 | TMI Products Vizualogic Headrest Pair...
Car Audio & Video Logo
272 people viewed this question
Top Microvision Inc Car Audio & Video Experts
xxxxxx xxx
Are you a Microvision Inc Car Audio and Video Expert? Answer questions, earn points and help others
