Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca hdtv model r52wh74 turns off after 25mins and wont turn back on. I have to leave it unplugged for a while for it to turn back on. I also had the convergence problem, switched the fuse, and it fixed it. But the tv shut off after 25mins and the convergence problem came back. please help???
  • elise42290 May 17, 2009
    you dont think if I replace the diode on the main power supply then the same fuse again and resolder the joints on the flyback it would fix the problem?
  • Anonymous May 17, 2009
    turns off and wont turn back on for a period of time
  • 431 Answers
Hi I am Vortash sorry to say you have an engineers nightmare fault an intermittent or slow to show .. this requires bench testing to catch the fault as it happens .. it will probably need an oscilloscope to monitor the psu and an MMM and a multimeter .. not the type of stuff most people have around the house unless you are an electronics engineer sorry to say but this is one for the man with the van .... Regards Vortash
Posted on May 17, 2009
  • clive pearson
    clive pearson May 17, 2009
    there is the possibility that dry joints are your problem and yes it may even be an intermittent bridge rectifier diode assembly but it is more likely to be an opto ic or a voltage regulator transistor with the fault you describe .. it may even be the fly-back transistor as you say .. but it may also be the fly-back transformer and if this is the set I am thinking about with three cathode projection tubes then the fault could be on either one .. one way of testing it safely as you say it comes on again after 25 minutes is run it till it goes off then disconnect from supply and get a tin of freeze spray and gently spray each component one at a time till set comes back on do not do it with the set live the spray is wet based and will blow other components till it freezes.. and you will have found your faulty component .. this is an easier way to try it if you do not have engineering training .. wear a pair of household rubber gloves whilst doing this as the can sometimes touches things you don't want it to and they will protect you .. I have to repeat unqualified personnel should never attempt to repair electronic mains powered equipment for risk of death or injury ... Regards vortash .. PS stay away from the tube anode cap the wire going to the transformer it can carry up to 19,000 volts ..
I have an rca hdtv, model r52wh74, that does absolutely nothing when i try to turn it on. what do u suggest?
That model is famous for the deflection board needing replacement. You can get The ITC222A deflection board from www.tvrepairworld.com
Apr 16, 2010 | Televison & Video
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
My rca tv model no r52wh74 goes off after a few minutes and wont come on until about 10 minutes then goes back off again?
What the problem is here is you have a bad power supply or you need to do a hard reboot. On this tv to reboot you need to unplug it from the wall and leave it unplugged for about four hours if not you need a power supply
Nov 20, 2009 | RCA R52WH73 Projection Television
RCA r52wh74 tv powers on then powers right off
one solution to maybe solve the problem of it not staying powered would be to take the panel off the back and use a blow dryer in the lower left hand corner and heat it up. It worked to get our tv turned on.
Jun 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
TV Changes Channels on its own
On the front panel board power/ch-/ch+ vol-/vol+ replace contact switches replace all of them.For some odd reasons these contact switches just keep going out they had alot of them bad.
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
305 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
