posted by hawjim on Oct 16, 2007
My Sony WEGA does not display a picture, either from cable, dvd, or other media. Had it fixed less than 100 days ago, Repair shop said it was one of the logic boards and claimed they replaced. When I power the tv on the entire screen is filled with multi-colored pixel like patterns (pink, blue, grey etc...) that are vertical in nature. I can see the tv menu screen over the top of it if used.
Comment by hawjim, posted on Oct 19, 2007
the repair place that did the work went out of business....murohy;s law. thanks for the advice
Best Solution
posted on Oct 17, 2007
If you still have your receipt for repair...take it back for repair again.
This time, you should have some kind of warranty on the last repair, so you should have to pay minimal (if anything) to get it fixed again.
If it is the logic board, insist that you are given the faulty one....that way you can see that it has been done and you can then dispose of it at your leisure, "knowing" you have not beem conned into paying for services not given.
Hope this helps
Hope this helps
Rating Locked! (?) hawjim has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Sony WEGA KE-37XS910 37 in.
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Sony WEGA KE-37XS910 37 in. HDTV-Ready Plasma...
4 yrs. old & vertical white... Answer This...
my sony flat panel...
sony flat panel ke32ts2u has no... Answer This...
double picture
double picture
i have a double picture with... Answer This...
SONY Plasma Vertical Line
What did you mean by your... Answer This...
Vertical Lines On Screen
About 9 Inches from left side... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
