Question about Hisense LHD3206US Television
Digital Television sound synchronisation
Just ''upgraded'' from analogue to Digital TV. Have HISENSE HSL8129HDI . Watching on DTV HDTV on ABC1 find that the sound lags behind the picture by a varying amount of time from a fraction of a second to enough for the sound for a short sentence to start after the lips have stopped moving. Impossibly annoying, especially as my partner is hearing impaired and lip-reads.
The supposed clarity and larger screen were the main reason for upgrading. Switched the same TV to analogue input and the problem disappeared.
HELP! Is this lack of synchronisation of picture and sound integral to the way Digital is broadcast, likely to be a set problem, or likely to be a transmission problem. Also Digital picture has occasionally broken down into visual squared scramble for a short time
    President:
  • Hisense Master
  • 1,779 Answers
The pixel problem your having is signal strength related, the sound is always affected first. If your on cable, have them come out and check the signal strength first.
Posted on May 17, 2009
Auto retune has wiped everything. Help
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
Lg 26lh2000 wont auto retune, help please.
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Hisense LHD3206US Television Logo
632 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
