Question about Toshiba 2060 Copier
Trouble with cassette
When I turn on my toshiba 2060, it makes a loud thumping sound in the paper area and says "cassette not working", and simply does not work.  Is there a replacement cassette,or do I need to get a new copier?
Thanks
Casset tray is faulty its alinement is not corect
Posted on Jun 11, 2008
    Problem Solver:
  • 5 Answers
CopyWarrior is correct. This is more likely to be the gears in the cassette lift motor are damaged.
Posted on Nov 13, 2007
    Problem Solver:
  • 9 Answers
Check to see if the tray lift motor is working properly for the tray.  I could possibly have a gear stripped causing the tray to not lift properly and making a noise when the gear skips a teeth.
If this is the case the tray would not rise to it's proper position and activate the tray height sensor therefore throwing an error code or message.
The tray motors usually can be accessed from the back of the machine and if you have more than one tray, you can swap them around to troubleshoot the bad one.
Posted on Oct 20, 2007
  • 163 Answers
My dear sir please open the cassetle feeding unit it have two sensors  ,may b there is some dust so please clean it .it is very good copier dont perchase new one it is very small fault only
Posted on Oct 17, 2007
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Toshiba 2060 gives Misfeed error. The copier is not picking the paper up out of the tray. There is no jam. What's going on ? Is there an easy fix?
sounds like the paper feed rollers are worn or dirty try cleaning the rollers if the problem persists then unfortunately you will have to replace the rollers
Apr 06, 2011 | Toshiba 2060 Copier
Add paper symbol is lit, paper is in it, but it w...
Paper tray up motor unit is available , in that unit there will be a tray up gear , it may warn out, you have to replace the gear
May 20, 2010 | Toshiba 2060 Copier
Toshiba 2060 copier shows paper jam at right side but I can not find any paper jam at all any other thing will cause to show paper jam? thanks mike
sometimes it does not sense that you opened the door that it says the jam was in. open and close the jam areas to see if it clears. if not restart the copier
May 17, 2010 | Toshiba 2060 Copier
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Dec 14, 2009 | Audio Players & Recorders
Toshiba 2060 problem with casette
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / damaged....one of the gears may be also damaged.
Sep 09, 2009 | Toshiba 2060 Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Toshiba 2060 will not print 1/2" from top side with letter paper
Have you tried the manual feed tray? Which way is the letter size paper being feed in? LTR or LTR-R. You may have a reg. clutch that is slipping. I would also look to see if you have any paper jamed behind the paper tray and make sure the paper trat is displaying that ltter paper is in the papre tray the same way as displayed. Good Luck
Feb 02, 2009 | Toshiba 2060 Copier
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Jan 11, 2009 | Toshiba 2060 Copier
101 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
