Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
My top loading Maytag washer, model: LAT8415AAE has stopped working. It will fill with water but will not start agitating. It does not spin or drain. Can you help>
  • tks_girl May 17, 2009
    Switch depresses completely but machine does not run. Is it possible that the switch has gone bad and needs to be replaced?
    President:
  • 3,113 Answers
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Maytag top loader won't agitate. will fill and spin
Try this:
When the washer should be agitating, try turning your load size switch back and forth a few times. If you are on a medium load, going to a larger load should cause it to begin filling again, going to a smaller size should start the motor for agitate. If this works, your pressure / water level sense switch is okay, but the switch for load size is faulted / or is on its way out. If you went from a medium load, to a higher load, then your pressure switch is faulted as well.
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
918 people viewed this question
Top Washing Machines Experts
