Question about Intertherm P3RA-048K Air Conditioner
Not blowing cold air
Why is the unit not blowing cold air
  • mike bare May 11, 2010
    make sure the compressor is running not just the out door fan check the capacitor to make sure not domed on top if domed then bad do you have air coming out of the duct vents
  • Ken Bledsoe May 11, 2010
    compressor might not be running. Might be low on freon
    Novelist:
  • 166 Answers
So as not to be repetitive (as others have had the same problem), here's a simple article that percisely explains the possible causes of your AC's not cooling:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Also, if need be for a Freon/refrigerant recharge (since only licensed techs can recharge), take advantage of the link towards the end for four free quotes from technicians if you find yourself need to get one. (You don't want to needlessly be charged for just someone's coming over only--it could cost a lot for no substantive action.)
Brad
Posted on May 25, 2009
  • 148 Answers
SOURCE: not blowing cold air
if the compressor is running and the filter is clean could need a shot of freon
Posted on Jun 21, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
james3751
  • 614 Answers
SOURCE: central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Posted on Jul 22, 2009
professio101
  • 158 Answers
SOURCE: the unit only blows warm air. it just stopped
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Posted on Aug 01, 2009
Heater not working
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | 2001 Ford Taurus
My new ac unit isnt blowing out cold enough
What's the temp been out side? If its over 95 degrees only expect you air to blow at about 75. It's an air conditioner not a cold air maker.
Sep 02, 2012 | 1986 Toyota Corolla 2 Door
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
UNIT WONT BLOW COLD AIR
The A-Coil is pluged up. you need some foamagator. it will foam up and clean your coils. don't forget to clean the outside coils also. but the one that is stopping the air from blowing is inside by the furnace. Hope this was helpfull
Saw
Aug 09, 2009 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
314 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
