Question about Smeg WD16BA Front Load Washer / Dryer
Drying operation on WD16BA on smeg dryer
How do you use the drying function only on the smeg WD16BA washer/dryer combo.  Or do you have a link to a manual?
  • dionysia Dec 01, 2008
    i do not know how to get the dryer to work at the SMEG WDI 12C washer dryer
  • Anonymous Mar 14, 2014
    It spins and stops but won't drain the water and door can not be opened
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Posted on Oct 03, 2008
How to drain the washer dryer
Try the rinse cycle. Rinse typically operates the pump to drain water from the barrel.
Hope this helps!
Dec 17, 2013 | Smeg WD16BA Front Load Washer / Dryer
I have a smeg wd 16 ba but do not have a manual, are you able to tell me what the difference settings refer to, such as the quickest wash, as ours currently takes between 4-5hrs and which setting is a hand...
Methinks you could do with a manual for your washer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 15, 2011 | Smeg WD16BA Front Load Washer / Dryer
Washing machine is showing Error 14.
The only listing I have for Smeg states for 'E14' 'NTC dryer in short circuit or interrupted'.
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man- it does say 'dryer' ;-0(
Jul 27, 2011 | Smeg WD16BA Front Load Washer / Dryer
What is the quick wash cycle for smeg wd16ba
Methinks you could do with a manual- for now and probably later!
John C.
Jul 06, 2011 | Smeg WD16BA Front Load Washer / Dryer
Does setting number 4, wash at 40 degrees?
Methinks you could do with a manual to answer these sorts of questions!
John C.
Jun 24, 2011 | Smeg WD16BA Front Load Washer / Dryer
Model ST121 S I need semering
I don't understand this semering. Please clarify and be very specific and I will help you.
Jan 22, 2011 | Smeg WD16BA Front Load Washer / Dryer
My built in smeg wd16ba ( I think ) washer dryer failed to drain. This has happenned before so i manually drained it and checked filter. I then found the usual spare pennies and hair grip. When I tried a...
Repeat what you have done and see if any wires were accidentely removved specially of the water level sensor. If so connect them once again . remove the plug from the power and reset the machine holding down pause with power plug in..
Checck tthe drain valve once again if the wires have shorted
Sep 17, 2010 | Smeg WD16BA Front Load Washer / Dryer
Not sure what programme to use for general washing as no manual
permanent press if you ahve it is the best one for just regular, normal cycle is better for towels and that type, longer more vigorous cycle
Jun 26, 2009 | Smeg WD16BA Front Load Washer / Dryer
Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Nov 11, 2008 | Smeg WD16BA Front Load Washer / Dryer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Smeg WD16BA Front Load Washer / Dryer Logo
379 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
