Green and black tv
I have a 36" Toshiba tv- tube. I bought it about 6 years ago. it recently posed a problem and im wondering if its worth fixing. the color went out of the picture and turned green and black. where it should be black and "white" it is green. is this a color jet and is it repairable for a reasonable price?
Thanks.
techman
  • 3130 Answers
SOURCE: Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Posted on Oct 08, 2006
SOURCE: Toshiba Color Television....now picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
chris
Posted on Mar 24, 2008
  • 4234 Answers
SOURCE: Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Posted on Sep 30, 2008
CAYPIANAN
  • 227 Answers
SOURCE: no picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
bhatgiri73
  • 106 Answers
SOURCE: My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Posted on Apr 02, 2010
Testimonial: "Great response... I basically needed to know if it is worth fixing (if its the tube) I like this tv and don't want to ditch for a new flat screen. thx"
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KP-51WS500 lossed it's green color...
FIRST YOU NEED TO LOOK INSIDE THE UNIT FROM BEHIND WITH THE COVER OFF AND SEE IF THE TUBES ARE LIT. AT THE BOTTOM OF THE TUBES BY THE CIRCUIT BOARDS, SEE IF ALL 3 ARE GLOWING ORANGE,(FILLAMENTS). IF THEY ARE ALL THE SAME THEN LOOK INTO THE LENSES AT TOP AND SEE IF THERE IS ANY LIGHT INSIDE. THESE SETS ARE COMMON TO HAVE BAD SOLDER CONNECTIONS ON THERE CRT BOARDS. EITHER LOST THE FILLAMENT CONNECTION OR LOST THE VIDEO DRIVE SIGNAL. LET ME KNOW, WE CAN GO FROM THERE. CAN YOU USE A SOLDERING IRON?
Dec 27, 2009 | Televison & Video
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
36 in toshiba
please model would want would say in a television toshiba to me cf2048, as I can abrir a little the vertical one because it has black strips in both sides as of centimetre of width, thanks, Gerald
May 17, 2008 | Toshiba 36A40 36" TV
TV making clicking sounds
if you had good color yes it is worth fixing sounds like your fly back trans former may be out see if you have any blown fusesif so get back tome for more help
Nov 02, 2007 | Sanyo DS31520 31" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Oct 07, 2006 | Toshiba 20AF46 20" TV
Wide black bar on bottom of screen
I you know how to repair electronics its not a hard fix. The worst case would be the vertical output IC but im thinking th its nothing more then a capacitor in the verticle sweep circuit The average cost to repair this should be around 75 to 125 bucks. Good Luck
Jun 01, 2006 | Toshiba 32A60 32" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
