Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
I install the unit about 5-6 years ago it is now leaking from a silver plate at the bottom of the unit. It looks like I can remove the plate and maybe install a gasker of some sort not sure it will work. Or do I replace the unit. This is my second unit I never had to replace the first one, I moved to a new house.
  • Anonymous May 17, 2009
    have the exact problem. I did take the silver plate off the bottom, but it is nothing but a cover to protect the wires underneath. I am frantically searching the web for a repair manual as the company did not email me one when i talked to them on the phone yesterday. Poor customer service..dead end there.
  • Anonymous May 18, 2009
    I have the same problem. I do not think customer service is even in the vocabulary of the Ermerson people I talked to. Sorry I could not help.
Flywheel seal needs replacing if disposal leaks from bottom plate.
Posted on Oct 18, 2009
If you remove the 4 male star headed screws that attach the top and bottom half of the unit you can gently pry them apart. Will be a little tough bc there is a tar-type seal along the inside. You will find a 2 plates, the upper flat one is the grinder and the lower is a bowl shaped plate which separates water from the motor. This plate after time gets rusted through therefore allowing water to get into the motor compartment and results in water dripping out the bottom of the unit. Discontinue use.
Unfortunately, this particular part is diffucult if not impossible to find anywhere. I may try to repair mine w/ JB Weld and some sheet metal, but I may have to buy a whole unit entirely. Hope this helps.
Posted on Jun 29, 2011
  • 44 Answers
Try this link to see if its in warranty or not:
http://www.insinkerator.com/service/trouble/dispose.html
If its not in warranty, you can put a bucket under it and drain it every now and then. Otherwise, you'd probably be money ahead just replacing it. That'd probably save some headaches, too.
Posted on May 24, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
The bowl like sealing plate between the motor and the grinder bits has most likely rusted through. This is by design so you will by another disposal. Get a Waste King 2600 or better to avoid problems for decades (they use stainless steel). Alternatively, InSinkErator also has some stainless steel models (above the badger line) but are a bit more expensive. http://66.39.51.245/wasteking/company/literature/pdf/LEGCOM-0307x.pdf
Posted on Jun 09, 2014
  • Isaac Brown
    Isaac Brown Jun 09, 2014
    The bowl like sealing plate between the motor and the grinder bits has most likely rusted through. This is by design so you will by another disposal. Get a Waste King 2600 or better to avoid problems for decades (they use stainless steel). Alternatively, InSinkErator also has some stainless steel models (above the badger line) but are a bit more expensive.http://66.39.51.245/wasteking/company/li...
2 Suggested Answers
SOURCE: my insinkerator Badger 5 plus 5 is leaking from the bottom plate
Hi treborzelazn, try this site: http://www.accuratehomeservices.com/store/toc_specs.asp
Posted on Jul 16, 2009
How does the bottom plate come off a badger garbage disposal
Hi, the only plate that should be removed on the bottom is for wiring the power cord to the unit. If there is water leaking, specifically from the bottom of the unit, it's leaking through the enClosure assembly which is not serviceable. If the unit isn't that old it might just be leaking from the sink flange or mounting gasket at the top of the unit which at times can be difficult to detect. Or possibly the gaskets at the drain assembly for the unit. Hope this helps ;)
Feb 01, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why washer leak from the bottom
You would need to try to clean out the coin trap in the bottom of the unit.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 09, 2012 | Frigidaire ATF6000ES Front Load Washer
How to install Delta T17030 Innovations Collection Single Handle Tub/Shower Trim Chrome by my self
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevE_13943.pdf
New Install:
1. Shut off the water.
2. Remove Plastic rough-in spacer. It's black and it's only there for roughing in, and so the tilers don't come too close.
3. Unscrew silver retaining nut - should only be hand tight. Remove and discard grey cap that was being held is place by nut. Remove and discard plastic stopper inside faucet.
4. Take grey plastic disk off of cartridge and DO NOT THROW AWAY. Adjust gearing/splines to hottest temp by rotating plastic insert. Reinstall plastic disk.
5. Install cartridge with HOT lettering to LEFT. Secure with Silver Nut.
6. Slide large O-Ring over silver nut.
7. Install trim plate using long phillips(star) screws provided (2)
8. Slide Plastic spacer (looks like a snowflake) into chrome trim (cylinder) and slide cylinder over Silver Nut.
9. Install handle by tightening allen screw until it engages firmly with cartridge.
Changing Existing Trim:
As Above Except Old Trim Must Be Removed First. Cartridges Are Specific To Certain Trims. Even More So If Installation Is Over 3 Years Old. 3 Years Ago, Delta Went To The "Universal Rough-In" Which Made Things A Little Easier Because The Appropriate Cartidge Now Comes With The Appropriate Trim.
Sep 08, 2009 | Delta Plumbing
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. Inside...at each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Dec 31, 2008 | Craftsman Air Tools & Compressors
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
14,717 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
