Is it possible to take a Whirlpool 3363736 and make a grinder?
Is it possible to take a Whirlpool 3363736 washing machine motor and use it as a bench grinder to run a wire wheel?
If so does anyone have the wiring schematics to hook it up? The wiring connection on the motor is part no: 62850 and has this color scheme: BK, V, W-BK, BU, Y, EMPTY, W, OR, EMPTY, R.
Any help w/b appreciated!
more details on the motor:
Part Number 3363736
Model number C68PXTRS-4419
1/2 Horse Power
115 Volts
60 HZ
Amps 9.8/ 9.0 RPM 1725 / 1140
Thermally Protected L
Ambient temperature rating 40 deg. C
  • t5825db May 17, 2009
    Yeah I know and Harbor Freight has one for $20 in the up coming sale but trying to go green and reuse.
  • t5825db May 25, 2009
    any other Guru's out there that have any answers?!?
    President:
  • 3,113 Answers
I see bench grinders for about ten or twenty dollars at the flea markets all the time. They also have the $$ grinding wheels on them.
Posted on May 17, 2009
When I turn it on, nothing happened.
motor either is shot or not getting electric . if motor runs then the belt is gone
Mar 08, 2015 | Delta 14-651 - Hollow Chisel Bench...
Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
Nov 19, 2014 | Bench Grinders
I have a ludell (machine tool) bench grinder. The problem is that the grinder disc will not turn. The motor hums but won't turn. I took the disc off and turned the shaft by hand with the powder on and it...
Ah, the start winding is not operating. When you turn the motor by hand. When the motor speeds up, do you hear a click sound? This is the start winding switch working. There might be a capacitor that is wired in with this switch that is used to start the grinder. If this capacitor is fried, the motor will not start. If the switch is shot, also the motor will not start. There could also be a wire or connector in this part of the motor that is not connected, or fried and not making contact. These are a few things to look for.
Jan 30, 2011 | Grinders
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 | Grinders
The motor just sits there and buzzes, when there isn't any electicity bearings turn freely
There is a short internally in the motor. IMO not worth repairing, new bench grinders are pretty inexpensive.
May 14, 2010 | Wilton 17202 8" Bench Grinder
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
Jan 22, 2010 | Delta Shopmaster 8" Bench Grinder
Bench grinder buzzes
The capacitor has failed. Take it out and go to a motor shop for a new one.
Jul 08, 2009 | Black & Decker Saws
Washing machine moter
green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
Nov 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
674 people viewed this question
Top Washing Machines Experts
