Question about Dryers
When i turn on the dryer, it makes a screeching noise and the tumbler wont turn...it is only 5 years old. It is model #110.64812200 and is electric. When I opened the door, it smelled like heat but I was afraid because it smelled funny.
  • 31 Answers
The bearings are worn out.u can get it repaired. some of the drumbs set on nylon pads. had the same problem. with ge brand. change then lasted about another year. when it went out again, i bought a new one [not another ge though] u can get parts off internet. hope this was helpful
Posted on May 17, 2009
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
Kenmore elile electric dryer screeches and now it wont run
Worn out. No solution to keep it running. Had a dryer I had to trash that did the very same thing........
Aug 27, 2012 | Dryers
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer is making a loud screeching noise when I turn it on, it is only 3 years old.
heatman101
Asker
Dec 29, 2010 | Whirlpool WED9200SQ Electric Dryer
My dryer GLEQ642AS makes a screeching sound, much like metal on metal, when running, but it still dries the clothes. Could a bearing need replacing? It is just 5 years old, but dries 2 loads daily. If the...
heatman101
Nov 30, 2010 | Dryers
Electric dryer makes a screeching noise while
could be your pulley or rollers or the motor itself you have to take the entire unit apart and visually inspect where the noise is coming from could be rear bearing if the model is old enough if you are not mechanical i suggest you call a tecnician hope this helps
Jul 15, 2010 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Mar 06, 2008 | Kenmore 62602 Electric Dryer
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
130 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
