Question about Intertherm P3RA-048K Air Conditioner
Condensation leaking out of unit
I have a nordyne model#33da-o36u-b upper unit and model#323b-017ha furnance and a heat pump in my manufactured home and every time I run the Heat pump to cool the house down it begins to leak water out of the bottom from condensation and when it shuts off I have a large puddle of water at the bottom of the unit. I have cleaned filters and tried to find a leak but am having no luck finding the problem?? Any ideas??
  • jeffrtodd May 17, 2009
    It is the upper unit indoors that is doing it. It doesn't seem to be getting to the drain lines at all.
    Problem Solver:
  • 19 Answers
If it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
Posted on May 17, 2009
  • heatman1976 May 18, 2009
    If the water is not even making it to the drain lines... then the unit might not be level, try and level the coil or make it so that it very slightly tilts to where the condensation runs gently towards the drain line. Make sure to seal any air gaps that are created during this process. Regular silicone will work fine for sealing those gaps.
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Nordyne FEH-017HA-04 furnace fan is running full speed on ac but not on furnace
Multiple speed fans are always wired to run on "HI" for A/C and a lower speed for heat. If there are more than 3 wires on the fan motor, its probably a multiple speed.
Oct 24, 2013 | Electrical Supplies
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
No voltage to thermostat inside blower does not come on and ouside unit does not come on. Nordyne/intertherm model E1EB-017HA
Check the breaker or fuse's then check power supply to the transformer you shuld get 24 volts out of it..
Aug 05, 2011 | Heating & Cooling
Arcoaire heating/air conditioner continually cycles condensation
a possible solution is to install an air dryer in line with this tube
Jan 03, 2010 | Calvin Klein The Field Controls Company...
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Pinging noise in duct work
it could be merely condensation or maybe the expansion and contraction of the metal as it heats up and cools down. if possible try insulating the vent if not done so already
Jan 27, 2009 | Aprilaire 700 Humidifier
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
473 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
