Question about Bionaire BT45RC Tower Fan
Makes a loud noise when it is turned on. Can't open it.
This problem has just started. The motor makes a loud noise when I turn the fan on. I tried to unscrew the body but cannot open it fully to check to see what could be the problem.
Any suggestions?
Thanks for your help in advance.
Shalini
  • 23 Answers
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
Posted on May 18, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Cooling fan makes a loud noise
You may need to remove the blower motor and check for debris in the box, or a failing bearing on the motor.
Sep 25, 2012 | 2003 Chevrolet Monte Carlo
Outside fan wants to start, but stops after 5 secs or so.
Turn off all power. Pull the cover off and lay it upside down so that you can reach the fan. Then turn the unit on and try spinning the fan blade with your hand while it trys to turn and makes the noise you observed. If it is seizing up or very difficult to turn by hand, the bearings are bad on your motor and the motor will need to be replaced. You might be able to lubricate the motor and buy a little bit of time but expect to have problems in the near future.
IF the motor does not seize up and starts spinning without resistance and runs for several minutes or so, you may have a failed capacitor.
Apr 03, 2010 | Ruud UBHC Air Conditioner
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
Bionaire BT45RC Tower Fan Logo
934 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
