Question about Printronix T5000 Thermal Printer
Error msg says "COLD PRINT HEAD"
Printronix t5000 has error msg say print head cold. How do I resolved this issue?
    Scholar:
  • 111 Answers
1. The Printhead/Controller
cable assembly is
disconnected.
2. The environment is too cold
for the printhead to sustain
operating temperature.
1. Make sure the printhead/
controller cable assembly is
connected to J401 at the
printhead and J6 on the
controller PCBA.
2. Move the printer to a
warmer location.
If none of this works you might have a bad printhead. The thermistor on the printhead has gone bad and needs to be replaced.
Please contact me if a printhead is needed or if you have any other questions. I am also an ASR for Printronix meaning I can supply you with new and used parts and printers.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 07, 2009
Cannon pixma mg5220 printer, b200 error msg. how do you remove the printhead ?
Error B200: A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair.
It can be that only the print head has malfunctions, but mostly it is another defect in the printer which causes also a defective print head. Changing the print head can solve the issue for a couple of weeks, but then the error will occur again.
May 06, 2014 | Canon PIXMA MG5220 Wireless Photo...
Printronix T5000 printhead hot
If this is in a Hot environment or printing heavy this is normal, but if not the head may need replacing.
Feb 18, 2014 | Printronix T5000 Thermal Printer
Canon MP600 printer, error msg. U052 Cleaning the printer head doesn't help. Replacing with new (full) cartridges doesn't help. The only one thing, that helps now, is to disconnect the printer from power...
Description
Reseat the Print Head to resolve the U051 / U052 error.
Solution
Errors displayed on the printer's LCD screen:
  • U051 Print head is not installed. Install the print head.
  • U052 The type of print head is incorrect. Install the correct print head.
Reseat the Print Head:
  1. Make sure that the power is turned on, and open the Paper Output Tray gently
  2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
  3. Remove all the Ink Tanks in the following manner.
    1. Push the tab (B) and lift the ink tank to remove.
    2. Do not touch the Print Head Lock Lever (C) while removing the ink tanks.
  4. Once the ink tanks have been removed, raise the print head lock lever.
  5. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
    *Before proceeding to next step, check the carriage area for packing material, torn paper, etc. and remove if found
  6. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
  7. Insert ink tanks into the print head.
    1. Insert the front end of ink tank into the Print Head at a slant. Make sure that the position of the ink tank matches the label.
    2. Press the mark (Push) on the ink tank until the ink tank snaps firmly into place.
      Make sure that the ink lamp lights up red.
  8. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Note: When the next printing begins, the print head cleaning will begin automatically.
If you have reseated the ink tanks and print head and the error still appears, our industry-leading support team is available to help you Monday through Friday from 10 AM to 10PM EST. You can contact our technical support experts by phone or email:
Call 1-800-OK-CANON (1-800-652-2666)
May 06, 2017 | Canon PIXMA MP600 all-In-One InkJet...
Im always getting an error msg.general error..Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on....can you...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 26, 2011 | Office Equipment & Supplies
What does it mean when you get a green and red flashing light?
Assuming you mean the error light is flashing red/green, that indicates that the print head is too cold. The only way to clear this problem is to let it warm up, then remove power for about 10 seconds (there is no way to reset the printer with power applied). This is to prevent the print head from damaging itself from extreme temperature changes. For example, if the printer was sitting in a car over a very cold night and you tried to use it first thing, the print head would go from freezing to scorching so fast, it could potentially shatter the print head. Granted, that is the worst case cenario, but it is still possible none the less. The printer checks the print head temp on start up only. This is why you need to cycle power.
Jan 21, 2011 | Pentax PocketJet 3 Thermal Printer
Error msg: Unable to print It states to refer to
Aug 22, 2010 | Brother MFC 210C All-In-One InkJet Printer
How do i clean the print head to a good printout
This is a Thermal Printer, which means it uses tiny hot wires to create dots on special paper to form the characters. There may be little to nothing you can do to make output better. You can try unplugging the unit from the power source and using a cotton swab dipped in alcohol to clean any paper fibers or residue from the face of the print head. More likely than not however is the possibility that you will have to have the print head replaced in order to restore crisp printouts. These print heads, much like the older dot-matrix print heads, have a limited lifetime because of the way they function.
Nov 20, 2009 | Printronix T5000 Thermal Printer
GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Jul 21, 2008 | Printronix T5000r Label Printer
There are two guides on that machine.
One guide will make sure that the media is locked down and secured. if it isn't it will cause drifting.
There is also another guide around the thermal head before printing that guides the labels before it prints. It either white or or it could be a green color.
are you using the takeup roller on the printer to hold the wax paper? If you are is it straight on the take up roller?
Jun 11, 2008 | Printronix T5000 Thermal Printer
Printronix T5000 Thermal Printer Logo
264 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
