Question about Toshiba Satellite A60 Notebook
Memory/RAM I wanted to put 1GB RAM into my Laptop, I tried it once before and put it in the slot under the laptop. It worked for a few hours but I was later forced to reboot the system. Should I try putting it into the slot again or should I replace the original 256 with the 1GB? Its the right memory I have double checked that already. Also my laptops kinda loud you can hear it working and its loud for the Libary, I was wondering if there is anyway to reduce it? The fan is clean. Thanks
  • 661 Answers
You are probably not using the correct type of memory, if you just bought a 1 gb stick, Laptops are pretty picky about what memory they use, check the Kingston Memory configurator to find out the max installable mem and which mem is correct to use.  http://www.kingston.com/ukroot/default.asp  use the Memory search feature on the right of the page to get you started
Toshiba satellite is a seperate section in the configurator, so choose that line to get more choices
Posted on Oct 17, 2007
My hard works but me screen will not come on after installing 2 GB of ram , but the screen works when I put in the 1 GB of ram...
A) ALWAYS helps if you post the laptop manufacturer name, and model number.
Model number is on the Bottom of the laptop.
B) EACH Ram Memory slot has a MAXIMUM Amount of ram memory it will support.
If the TOTAL Maximum Amount for the laptop is 2GB, plus there are two Ram Memory slots, and the Maximum Amount for EACH ram memory slot is 1GB, what you are doing = NO.
Awaiting laptop manufacturer name, and model number.
C) Also, post what you see on the 2GB ram memory module, or info elsewhere for it.
Need to know WHO made it, and what it's specifications are.
May NOT be for YOUR laptop.
Regards,
joecoolvette
Feb 16, 2013 | Computers & Internet
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Adding an additional memory module to laptop...wont start!!!
The problem is that your laptop only supports 2 GB of RAM. If there is not a newer bios allowing more then 2 GB is the max you can go. Since you put the 2 GB in one slot then the other slot will be useless. It wouldn't matter how much you put in the 2nd slot because the bios already says you have 2 GB on board and will not accept anymore. Sorry.
Apr 08, 2009 | HP Compaq Presario C500t Notebook
Ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
Apr 01, 2009 | Computers & Internet
I can't find the second ram slot
Lots of laptops have the second slot under the keyboard. If you are adventurous take the keyboard off and look in there.
Mar 11, 2009 | Evesham Computers & Internet
T 30 IBM MEMORY PROBLEM
Hi!
Call 800-IBM-SERV and describe the problem. Say that you heard that there's an "engineering change" available to correct it, described in document MIGR-44772.
Repair should be free within the warranty period, and probably free even outside the warranty.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 10, 2009 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Ram change problem
There should be a reset button on bottom of laptop....if not...remove battery, power supply plug and remove the mbottom panels....under one of them is a battery the size of one of two....either 6mm in diametre or one of 22mm in diametre...remove it and leave laptop for about 5 min....remove memory,touch the memory's golden edges briefly with your fingers to discharge charge in memeory.put everything together...should solve your problem. JJ
Sep 13, 2007 | Dell Inspiron 6000 Notebook
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
