Question about Hitachi Performa CP-RS55 Multimedia Projector
Internal fuse hi i accidently jogged the mains input on the projector which then caused the internal fuse to blow i replaced it but it keeps blowing everytime i put the main plug back in now and i have retryed this over 5 times now and it still fuses please please help me!
  • makky2008 Sep 11, 2008
    Where can i finde the Internal fuse ???
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Posted on Nov 17, 2007
What causes mains fuse to blow ?
A large short!. A short is a hot wire unintentionally touching ground- a metal piece of the frame. It will immediately cause sparking and blow a fuse. Also, an electric motor can have an internal short and blow the fuse for that circuit.
To find what is blowing the fuse, you have to follow every circuit that fuse protects until you find the source of the short. Look for burnt wires, like maybe too close to exhaust. Also a shorted wire can be bundled within a wiring harness, touching other wires and blowing a fuse. Since it is a main fuse, you will probably need a wiring diagram to trace all the circuits which that fuse protects. Try to isolate parts of circuits, like disconnecting the electrical connector at the ignition switch and then see if a new fuse blows. Keep working through each circuit like that until you see results. If some part or component is disconnected and the fuse doesn't blow, then you may be onto it- it could be that part you disconnected, or the wiring associated with the part.
Find a wiring diagram and see what all is part of that fuse. Good luck.
Oct 14, 2017 | Cars & Trucks
My 2006 dodge ram 2500 diesel keeps blowing fuse
The Internal light is normally tied to your dash lights on a factory installed radio. Find the main p[lug on the back of the radio and unplug it then try it with a new fuse if it still blows then it is the wiring if it does not blow the fuse when the radio is unplugged, chances are the radio is bad and will have to be repaired or replaced.
Sep 16, 2014 | 2006 Dodge Ram 2500
Why is my inverter keep on blowing fuses?
You probably caused an internal short circuit.
Sep 15, 2014 | Electronics - Others
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
No power braker ok
There is an internal fuse on most microwaves, it will "Blow" if the door interlock switches are not happy, sometimes the fuse just blows, like some circuit breakers do.. get a few extra, replace it and see what happens..if it doesn't blow again, you're most likely ok, if not, there are more causes for the internal fuse to blow, beyond the interlocks, it's not going to be cheap.
Oct 25, 2009 | Maytag Microwave Ovens
No power and no clock or light
Internal fuse, Dangerous for the untrained. Have to find the cause for the fuse blowing. Eric
Aug 08, 2009 | Microwave Ovens
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
Can a internal slow blow fuse be fixed?
Any internal slow-blow fuse can be replaced with one of the correct value. Fuses do seem to have a finite life, so occasionally you can just replace the blown fuse  with an identical one and all will be well. However, fuses are protection devices , and it's more likely that you have a  short circuit or  defective component in your VS3251 that's causing it to draw too much current , and the internal fuse is blowing to prevent further damage. ie the fuse blowing is the symptom not the problem. Never replace fuses with ones of a higher current rating. Slow-blow fuses have the suffix T (for "Time Delay", and normal ones have F ( for "Fast"). With the street price of the VS3251 , a commercial repair is uneconomical
Feb 01, 2009 | Electronics - Others
Hitachi Performa CP-RS55 Multimedia... Problem
ok " sounds like you have a short, thats why it's blowing fuses
Nov 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi Performa CP-RS55 Multimedia Projector Logo
264 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
