Question about HP LaserJet 3330 All-In-One Printer
The display of my HP Laserjet 3330 says that "scanner Bulb Warming up". It has been there for last few days. Rebooting does not help.
  • 21 Answers
The scanner bulb mirror needs to be cleaned.
Posted on May 26, 2009
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Cant print. says printer is offline, printer says scanner bulb is warmimg up. im using a mac
Your issue is caused by dust in the scanner optics. Here is a link to a web page with instructions on cleaning the optics and clearing the error.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 21, 2011 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
SCANNER BULB IS ALWAYS WARMING UP
The "scanner warming up" error is caused by dirty optics in the scanner assembly. You will need to dis-assemble the scanner and clean the mirrors with window cleaner and lint free towels and Q-tips. We have a stap by step walk thru article on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ The repair should take about 30-45 minutes to perform. The repair will require you to dis-assemble the scanner unit so be prepared to do a little work but when finished your printer will work just like new.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 01, 2010 | HP LaserJet 3380 All-In-One Printer
Hp laser jet 3330 will not reset with acquired instructions and bulb warming message stays on.......i've tried to unplug unit....stays the same. cancel button also stays lit
You need to take apart the top and clean the scanner bulb and mirrors, if cleaning does not help then you need a new scan assembly. Usually costs more than a new machine.
Jul 14, 2009 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
Service tech seeks service manual in .pdf for hp laserjet 3330
Any HP printer. All parts diagrams:
http://partsurfer.hp.com/cgi-bin/spi/main
Apr 02, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
333 people viewed this question
Seeker5211
Seeker5211
