Question about Maytag Neptune MAH7500A Front Load Washer
Washer door would not open
My daughter's 2 year old MAH7500AWW washer door would not unlock (with a load of wash inside). She called Sears for service. The service man unlocked the door but told her the problem was the curcuit board in the top control section. The repair bill would be $600.00.
Does this seem like the correct diagnosis to you? And I found the board online for $200.00.
Is there anywhere I can ship the curcuit board to for a second opinion and/or a reasonable replacement cost?
Thanks.... Harold Beiter, Hudson, FL
  • hawold Oct 18, 2007
    Thanks for the good feedback, dr. I think your website is a great service for the general public.
    Hudson is located just north of New Port Richey, on the gulf coast... about an hour north west of Tampa.
    Look forward to tapping your expertise in the future, as necessity dictates.
    Keep up the good work.
    Harold
  • 447 Answers
Hi Harold From my parts breakdown too That part is $580 its so expensive because it a touchscreen LCD. I have had some (nonLCD) models doing this and it has been the Main Board sometimes, you may want to pay for a 2nd opinion. Where is Hudson?? Im in Tallahassee
Posted on Oct 17, 2007
My whirlpool duet front load washer thre a code 28 and cant get the washer to finish cycle and can not get door open
Bottom front panel comes off is a release lever you can pull to open the door,inside that panel is also where they hide the manual. Sears repair told me the electronic brain box go/s after 2 years
May 25, 2015 | Whirlpool Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Why does my Maytag Neptune Washing machine smell like rotten eggs everytime I turned it on? Maytag Neptune MAH7500AWW Serial 70802618ZM
you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
Nov 08, 2009 | Maytag Neptune MAH7500A Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
There is wash in the washer and the dcor is locked but the cycle isn't going
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 04, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore frontload washer won't unlock
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Apr 01, 2009 | Washing Machines
Washing machine won't open
Mar 18, 2009 | Washing Machines
Door popped open during the wash cycle and now will not close
Mar 08, 2009 | Kenmore Washing Machines
F 29
bring it back they have a return guarantee.
Nov 04, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH7500A Front Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
