Question about Universal Remote Control DIRECTV Universal Remote Control
Need Philco STB code for Philips universal remote
I need philco STB codes for philips universal remote. And which mode button to program them in? Direct TV remote. Found this on Internet:
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite  - 0
TV - 1
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Sounds like a pain in the a**
  • audacious May 17, 2009
    The previous post by audacious should read, "Philco STB code for a Direct TV universal remote". The possible fix I quoted  comes from Direct TV site and apparently is just a way to cycle through every known code available. Obviously this is why it takes so long. Trouble is, Direct TV Satellite sets may not have the Philco code yet.
3 Suggested Answers
  • 12 Answers
SOURCE: No video on tv monitor
To permanently fix the problem you have to send the unit to a programmer. A quick fix would be is to physically do it in your TV. While your Direct TV satellite receiver is ON, press the "TV/Video" or "Source" or "Input" button in your TV until the video will appear in the TV screen. All the TV has either one of this button.
Posted on Sep 01, 2008
  • 34 Answers
SOURCE: I have a RCA Universal
try this
10180, 10171
Hope this helps
Rate my solution please!
Posted on Feb 01, 2009
Unfortunately you have a television that doesn't exist. It is probably made by a company and badged Polytron.
ORION Codes: 035/ 121/ 135
  • PANASONIC Codes: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
  • PHILCO Codes: 003/ 004/ 005/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 077/ 133
  • PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
  • PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
  • PILOT Code: 004
  • PIONEER Codes: 004/ 009/ 090/ 179/ 185
  • PORTLAND Codes: 004/ 005/ 009/ 058
  • PRECISION Code: 166
  • PRICE CLUB Code: 105
  • PRISM Code: 055
  • PROSCAN Codes: 000/ 031/ 107/ 181
  • PROTON Codes: 004/ 009/ 093/ 175/ 186/ 192
  • PULSAR Code: 121
  • PULSER Code: 004
  • QUASAR Codes: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
    Jul 04, 2016 | Universal Televison & Video
    Philco codes for model sz500
    Codes for Philco TV, with RCA-RCR311W model remote control are:
    1002, 1004, 1009, 1014, 1025, 1046, 1051, 1053, 1054,1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1076, 1077, 1078, 1082, 1083, 1085, 1091, 1133, 1205, 1230
    Jun 26, 2012 | Philips Televison & Video
    I used the 0171 code for my sylvania TV model 6419ta and it still didn't work
    With Philips which is Sylvania, Philco, Magnavox and Philips there are so many different codes in use a Universal or programable remote is usually useless.
    If you have the original and it does not work--see about getting it fixed (usually under 10 dollars) and if not look for the original one new.
    Apr 29, 2012 | Sylvania Televison & Video
    I have a philips universal remote control and I need the code for a philco tv. Joe
    Which of the many Philips universal remotes do you have? lists them all. Then use the remote code finder to look up Philco. For example, the code 2192 is the Philco code for the SRP 4004.
    However, the codes built into the remote may not work if the remote is older than the TV (or was programmed within 6 months of the TV's release). There is a time lag for codes going from the manufacturer to the universal remote makers.
    I hope this helps.
    Sep 23, 2010 | Televison & Video
    I have a Philco DVD player and a Philips universal remote and none of the codes that I have tried work.
    go to rca universal remote it gives you a ton of codes the remote may be a phillips but the code is philco so there may be codes there that are not in your manual
    Aug 19, 2009 | 2001 Dodge Intrepid
    Need universal remote code.
    If you have your model number for the Phillips remote, you should be able to locate it here. Hope this helps.
    Aug 19, 2009 | Sony DVP-NS57P
    Trying to program Philco URC-2070 remote control
    I determined that the Philco Remote Control that I wanted to program for use on a Magnavox tv was too old (20+ Years) and dead. It also did not have the features of a new Universal Remote. So, I tosed the Philco remote and purchased a new Universal Remote Control.
    Thanke you..
    Mar 19, 2009 | Philips Magnavox 20MT1336 20" TV
    Need codes for Philco universal remote URC-2070
    I have a Silvania TV and need the programming codes for the PHILCO Remote urc 2070
    Thank you for your help.
    Jan 03, 2009 | Sharp 21" Multi System Stereo TV
    Philco remote URC-2070/admiral tv code?
    Asked someone else who knew the three numbers to program my tv.
    Nov 26, 2008 | RCA 4-in-1 Universal Remote Control
    Televison & Video Logo
    389 people viewed this question
    Top Universal Remote Control Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
