Question about Vestax Cdx05 Table Top CD Player CD Player
Keeps having error 02 after cleaning lens and CD
I have a Vestax CDX-05, CD player. The player comes up with error 02 when I try and play a CD. I will then use a CD player cleaner and clean the CD, the player will work again for a day and then stop playing the CDs again and makes a turning noise as if the CD is off balance when trying to read the CD. Error 02: GFS error, GFS signal cannot be detected within 5 seconds - solution from vestax try with another disc or clean disc and try again.
5 Suggested Answers
  • 3 Answers
SOURCE: Pitch control center now 3.2% off center
Turn on CDX, hold down Time/Enter and Spin the jog wheel at the same time. This will bring up a selection. Select Clear All then Enter when it says Sure! This resets all programmable settings back to factory default.
Posted on May 13, 2009
SOURCE: Vestax PDX200 platter keeps changing direction
Hi everyone,
I had exactly same problem with my Vestax pdx 2000 mk2 TUNETABLE.
The solution involves some careful screwdriving but is fairly simple....
You need to take the motor out and carefully take it to pieces, the problem is caused by a tiny piece that needs to be put back into place. Of course you will loose your warranty but its cheaper and faster then getting new motor or sending to repair.
If u need help don't hasitate to email me: jazzbin@o2.pl
i can explain every step and send u step by step pics of the repair.
Posted on Apr 23, 2009
walesarumi
  • 6993 Answers
SOURCE: vestax cdx-12 , left hand cddrive doesn't
In that case, the lens is weak. You need to change the lens entirely.
I wish you the best of luck.
Posted on Nov 06, 2009
SOURCE: vestax cdx-05s
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Posted on Jun 18, 2010
Vestax CDX-05 stutters and clicks when ejecting cd. Not all the arms on the transport assembly move when trying to eject a cd.
well to be honoust, it would be the best, but not price wise. I can't help you, only let a pro look at it with you by your side. It turnds and grabs the side and yesterdat i reard that loose components can be installed......
Dec 18, 2012 | Vestax CDX-05 Turntable
My CDX05 kept skipping last night, it happened on 7 different CDs. The CDX was tilted up though, would this cause the problem?
If it was kept in a dusty place yes!
I would thus try cleaning the lens with a good CD lens cleaner product, that should get rid of any dust problem.
Apr 07, 2010 | Vestax CDX-05 Turntable
Vestax cdx-12 , left hand cddrive doesn't recognise discs imediately , sonetime not at all
Nov 05, 2009 | Vestax Cdx05 Table Top CD Player CD Player
Laser
The laser is probably dirty... Lasers last forever, or 100,000 hours of play, whichever comes first.
Use a CD laser Cleaner ... Radio Shack ($14)
It is a Audio CD with small imbedded brushes. No chemicals involved.
read the instructions carefully and turn on the volume when cleaning. The CD is an AUDIO CD and it will also give audio instructions.
Hope this helps! ... Don't take the unit apart...
Sep 08, 2009 | Vestax CDX-05 Turntable
Vestax cdx-05s
Jun 24, 2008 | Vestax CDX-05 Turntable
Sony cdx-4000x
if you are playing original cds with no scratches try a cd lens cleaning disc if that fails it sounds like the laser
May 21, 2008 | Car Audio & Video
maybe you should try a firmware update .follow the links on the vestax website about product support .
Dec 08, 2007 | Vestax Cdx05 Table Top CD Player CD Player
Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
Dec 08, 2007 | Vestax CDX-05 Turntable
Vestax Cdx05 Table Top CD Player CD Player Logo
377 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
