Question about Kyocera FS-5025N Laser Printer
I get a repectitive blue dot down the right hand side of the page
It doesn't happen with monochrome pages, only colour. The dots are 94mm apart.
I have only done 300 pages since it was being serviced for paper jam problems. Crunching gear noises prior.
  • 74gremx May 16, 2009
    PS to the above query. I can't spell 'repetitive', and the printer is a Kyocera FS-5025N
    Thanks,
    Dave
  • 74gremx May 23, 2009
    Thanks - got a tech in, he said it needsa good clean out, which begs the question; whay wasn't that done when they had it there 300 pages before ? Any way, it's going well so far.
    Another query with this machine: when printing pdfs I sometimes get black shapes appearing on the page, with sharp edges, and are actually layered under text and or images on the page. Print the same page again, it's gone. I have a few examples of these.
    Maybe one in 500 prints ?
    Dave
  • 326 Answers
Sounds like it may be an Image Transfer Unit issue, inspect for debris or excess toner.
Any ghosting or permanent residue is sign of a unit going defective.
Posted on May 17, 2009
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Aug 24, 2009 | HP LaserJet 2840 All-In-One Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Kyocera FS-5025N Laser Printer Logo
329 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
