Question about Compaq ( 277498-001) Motherboard
Motherboard 277498-001 setting jumpers - help please
Mb 277498-001 setting jumpers - help please!
I can't find info about settings jumpers of this mb 277498-001 , socket 478, sdram, p4
thank you very much for your help!
    Sergeant:
  • 449 Answers
Visit http://www.compaq.com and select the product then download the user's manual. Such informations are usually given in the users mnual. Although Compaq is presently owned by HP, but user support is still there. (ehteshamhusain@gmail.com)
Posted on Jul 18, 2009
Hi - I just bought an Asus M4N78 Pro mb. It will not detect my 2 IDE drives. I have checked the bios and IDE controller is enabled. I tried 3 different CPU's with no difference. Also made sure that the...
Make sure your ribbon cables are pluged in corectly? make sure your jumpers on your Hds are set right? your power connectors are in corect? and set up your bios for your Hds and then when reconized partion and format thr drives. hope this helps! Remember your jumpers on your MB too!
Jun 02, 2011 | ASUS M4N78 Pro Motherboard
My asus mb can't start windows normaly
There is a jumper setting for bios in the motherboard. Please change the jumper settings so that the other 2 pins get connected. The try to reboot again.
Dec 10, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Jan 07, 2010 | Soyo SY-K7VME Motherboard
Set CPU/FSB speed on KT40A-ANH MB
Don't screw around with jumpers. There are a buttload of fan speed hacks for software on the computer. Google Fan speed hack and you might find one that works.
Sep 27, 2009 | Pine Technology (KT40AANH) Motherboard
Not booting up
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Thanks for using fixya.
Please rate solution if it helps.
Jul 18, 2009 | Biostar M6VLR PLE133T Socket 370 mATX MB...
SETTING J3 IN PCCHIPS M812LMR
Most of the time the jumper is near the backup battery for your bios.. It's next to Dimm2 on your MB.. Good luck!
Jun 02, 2009 | PC Chips M871G Motherboard
I have motherboard Compaq #277498-001 P5008640WP8N2BSM AS#253242-002 DG#011346 and can't find information for jumpers setting, please for help-marior77@abv.bg
What model does this MB belong to? If it is a newerMB the only jumper settings you should see would be the clear BIOS jumper. Alot of the newer motherboard settings are done thru the BIOS.
http://www.compaq.com/cpq-country/cpq_support.html
try looking here
good luck
May 16, 2009 | Compaq ( 277498-001) Motherboard
Hi, I want to add a 750gb hdd to my PCCHIPS K8M800 M861G V1.6 Motherboard. I already have a 200 gb connected with the OS etc on. When I try to boot it keeps recycling through the POST. Can anyone help...
hi,
check with the BIOS settings about the Primary and secondary hard disk. Select the bootable Hard disk as Primary by changing the Jumper settings. Make the other harddisk as secondary by changing the jumper setting as said on the label of harddisk. Now you try to boot, your problem will be solved.
Apr 19, 2009 | PC Chips MB PCCHIPS M861G V1.6 K8M800 754...
Asus A7V8X-MX SE and Sweex CR005V2 connection problem
It is quite possible to plug the socket in "back to front" have your tried rotating the plug 180 degrees?
cheers
Andrew
Sep 20, 2008 | ASUS A7V8X-MX SE Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Compaq ( 277498-001) Motherboard Logo
630 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
