Question about La Pavoni Europiccola EPC-8 Espresso Machine
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
    President:
  • 1,618 Answers
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
Posted on May 17, 2009
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
May 22, 2014 | La Pavoni Coffee Makers & Espresso...
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
What causes my la pavoni europicola to make a whistling sound when it;s turned on?
Contact Authorized Service. Before their approval, don't use it or it maybe hazardous.
Apr 26, 2014 | La Pavoni Coffee Makers & Espresso...
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi
it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close
but if it continue to whistle when the green light goes off
after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve
in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat
regards
Guy
Dissasembling Pavoni Europiccola
Try looking at this site its really good helped me do various repairs to my La Pavoni Pro
http://www.francescoceccarelli.eu/lapavoni_faidate_eng.htm
all the best P
Apr 12, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
I can't get any water out of my machine
rod into piston may be slack stopping water coming into group at inlet hole - take piston out and tighten rod. I had this same problem and this fixed it for me. Slackening occurs through time - maybe too much coffee in basket and forced onto base of group.
Mar 28, 2007 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
275 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
