Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Engine runs good and blades turn fine but the lawnmower does not move forward or reverse.
  • John C Bridgers Sr May 11, 2010
    Hello hiranomy:
    >>Are you Sure the Belt is Still on the Pulley System?
    >>Is the Transaxle Pulley Turning?
    >>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
    >>On the Transaxle is an OEM Identification Plate. Send me the Information Off of This Plate, Please. With this Information, I can Locate the Proper Manuals and Better Assist You.
    Thanks.
    Respectfully
    jbridger (John)
The freewheel control is in the wrong position. push in all the way for mowing. This control is located on the rear of the mower below the seat.
Posted on Jun 08, 2009
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I Have a push mower and hit a rock and finished the lawn hearing the lawnmower blade hit underneath a couple of times. When the mower went down slope the blade started really hitting the side. The next...
hi there nchernuka
have you checked that the engine to chassis bolts are still tight and the mounts are ok,
have you checked that you havn't bent the pto shaft ( this will be evident if you remove the blade carrier and blades, then the plug and pull the gine over - check wobble ), check that blade carrier is in good condition and the pto woodruff key is ok and the carrier centre pto bolt is tight
check that anything that is under the mower body is still tightly attached and is not getting swung into the path off the blades - ie catcher tounge - metal body brackets etc
i would also suggest you check the feather timming key in the flywheel too especially if it kicks back when you try to start it
cheers have a look
hope it helps pauly46
May 27, 2011 | Garden
Lawnmower wont move in fwd or reverse
Is the brake sticking. On my craftsman mower there is a bar under the brake pedal that pushes back a lever when starting. And the lever sticks. I have to reach underneath and pull the lever forward and then the mower goes. I haven't found a solution to that yet.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drive and blade engagement shutsdown the engine.
Sounds like the seat safety switch.
Mar 05, 2009 | Poulan Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
974 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
