Question about Boating
Boat motor won't turn off !
I have a Yamaha T-8 That runs great but now that I have moved it too another boat I cannot get it to shut off. (It has remote controls)
Key nor the kill switch will not turn it off. I had to pull a coil wire.
I have verified all Wires are connected color to color and all ground wires are in place. I also noticed the remote Choke is not working.
??? Ground issue ??
    Problem Solver:
  • 5 Answers
Im not sure on your motor but if you have a choke tube with a cylinder in it the cylinder could have came out take the top off and hit your choke and see what moves
Posted on May 25, 2009
Weight of 17 foot fibreglass boat and 115 horsepower Yamaha motor
the weight of the motor will be obtainable from the Yamaha web site in the specifications section the weight of the boat is any body guess as you didn't give a manufacturer name
most marine shops will get close as they are familiar with boat constructions and supply trailers to suit
Aug 01, 2017 | Yamaha Boating
Looking to repower 1997 Four Winns bowrider with newer outboard engine. What max HP is boat rated for? Found Yamaha 150 XB 2016 for a good price . Will boat work with a 25 inch shaft? Thanks,Kathy
there should be a manufacturers plate attached to the hull of the boat with a number of passengers it can carry and the max hp motor allowed to be fitted
talk with boat shops as they will know the approximate hp for each make of boat and length
while it may be attractive to fit big hp motors to small boats , it in fact makes the boat less sea worthy and makes capsizing easier so get the advice right from the boat shops
Feb 07, 2017 | Yamaha Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
Boat motors
sounds like you have a bad power pack..
Jul 22, 2013 | Boating
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
I have a 2005 90hp yamaha on a 17' xpress bass boat. i can only turn 5200 rpm when you get to 4800 rpm the boat starts bouncing.
Check the running height of the motor.The prop shaft should be about one inch below the straight line of the bottom of the running bottom of the boat.With a cleaver prop it may be lower.A chopper prop is the best and you can run every bit of that.2 inches if pitch is = to about 500 revs.Try a few props 1st before you pay the dollars for a new one.The bouncing is the wrong transom height and prop.You don,t need a cav plate if the boat is set up right.(a cav plate extension like a manta).Bad dealers may want to sell you these.A well set up boat doesn't.I've set up and run a lot of ski racing boats and all have never needed any "bolt on parts".Its mainly a motor height and prop selection thing.Hope this helps
May 05, 2010 | Boating
High Battery alarm goes off while boat motor is running
power supply for the radio taken from a source wire that is affecting the voltage regulation
take it in or have a radio technician come and check the installation
Jan 09, 2018 | Uniden Solara DSC VHF Marine Radio
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
1,094 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
