Question about Frigidaire FRS23R4C Side by Side Refrigerator
The motor in the icemaker is grinding and sosunds like it it frozen up. It will not turn off except to turn the entire refrigerator off. How can I stop it until it is repaired? # is FRS23R4CB
  • cnewman2 May 17, 2009
    I can see it but can't get it out. I'll keep trying. Thanks.
    Thank you so much for the extra advice. Now we can use the refrigerator until it is repaired.
    President:
  • 2,559 Answers
You can unplug the ice maker inside the freezer,The plug is located just under the ice maker and plugs into the left wall.You will need to remove the ice bucket to get to it and slightly push up on the ice make to get the plug out.
Please take time to rate this fixya.
Posted on May 16, 2009
  • Randy Hough
    Randy Hough May 17, 2009
    you can also,loosen the 2 screws on the top and of the ice maker going into the same wall and lift the whole thing off.
  • Randy Hough
    Thank you and please consider changing the rating to a fixya.
Our icecube maker has stopped working on our Kitchenaid Model KBLA20EMSS Any suggestions on what the problem might be?
unplug the unit,remove the entire icemaker,then the motor module from the front that operates the harvest and all features,and manually rotate the motor,then re-install the motor on the icemaker and re-install it into the refrige and plug in the refrige,sometimes the ,motor glitches, and after you manually turn them it gets them going again
Aug 11, 2010 | KitchenAid KBLA20EMSS Bottom Freezer...
Icemaker rakes not moving, though it is in the cycle and making a lound humm, grinding type sound (similar to when it does its normal ice rake cycle.
Normally, icemakers make very little noise. If it is in the middle of a harvest cycle and will not complete the cycle, remove the icemaker and look to see if an object some how fell into the ice cube mold area, preventing the rake from turning. If there is no obstuction, you will have to buy a replacement icemaker, as there are no replacement parts available. NOTE: Do not leave the icemaker in your freezer in the middle of a cycle for extended periods, as the mold heater would be "on" and adding heat to your freezer section the entire time, causing your refrigerator to work harder than normal, and costing more to run.
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker not makeing ice anymore
check the output power supply
Jul 07, 2009 | Refrigerators
Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
May 31, 2009 | Maytag MSD2454G Side by Side Refrigerator
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
No water or Ice
chances are your waterlines and motor are frozen, which indicates you may have a leak somewhere, causing ice build-up
Jan 31, 2008 | GE GSH25JFR Side by Side Refrigerator
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Whirlpool side by side refrigerator - grinding noise from icemaker
That would likely be the ice maker "motor module". They are notorious for failing. The plastic gear on the front pulls away from the contact springs from ear tab failure, etc. It's an easy fix to replace the whole module (about $70 bucks). See the diagram here. http://www.partselect.com/Schematics/Whirlpool/THIERSZO.gif
Jan 14, 2007 | Whirlpool ED2FHSS Side by Side...
Frigidaire FRS23R4C Side by Side Refrigerator Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
