Question about Panasonic Audio Players & Recorders
Fan model number
Sadk20 replacement fan or equivelent replacement part
Us website
instead of canada
thanks
Posted on May 17, 2009
I WOULD LIKE TO KNOW EQUIVELENT OF TDA9340PS/N3/A/1923
If you enter the IC number into Google you can find places that have the original model, so why would you want an equivalent?
Feb 11, 2014 | LG 47LB9DF LCD TV, 47 ViewabImage Size,...
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
Need owners manual for a kenmore elite washer that is free
What is your model number..also to let ya know Sears does charge for manuals. HOWEVER Sears doesnt make that washer that have it labeled for them..so with the model number i can determine exactly who made it..very likely Whirlpool and send ya a manual for that exact equivelent machine which will be identical except on the front where yours says Kenmore that one will say WHIRLPOOL
Whirlpool does not charge for manuals
or even if is made by General Electric their maunals are free as well..only Sears charge to send ya hard copy in the mail and wont allow a pdf electronic versoin of it to be downloaded free
Aug 24, 2011 | Kenmore Washing Machines
Red light does not come on when buttoms pressed ,even with new battery,an I obtain a new remote?
Hi and welcome to FixYa, I am Kelly
Kmart and Sears both have replacement remotes for Hunter Fans.
Look on the back of your remote for the model number and you can search
http://searspartsdirect.com using a model search for a replacement.
You can also call the Hunter Fan Company to find out the model of your remote here:
1-888-830-1326. They will ask for the model number of your fan.
The Hunter remotes for the original fans can be one of these 3 models: 27187, 22691 or 27189.
See if you can find one of those 3 numbers on your remote.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
I have a poulan 20 inch model pp4620avhd bought an oregon chain model h78 is this the right one
That part number does not cross. If the original or equivelant 20" bar find it here (all 0.325 pitch with 78 drive links; AV, AVX or AVHD):
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Replacement motor for table saw craftman model #113.12171 zip code 11725
I would suggest taking the motor to a Grainger or equivelant type of business and they can probably match it up with a Dayton motor that would replace this one. They will need all the information off the data tag to match it up.
Nov 14, 2009 | Craftsman Saws
CFL bulbs won't work in ceiling fan?
they should all work. The only problem might be if they are connected via dimmer. Dimmers and CFL does not work together.
Mar 08, 2009 | IBM ThinkPad R50e Notebook
NOT SPINNING ONLY CLICKING NOISE
sojnds as if you have a bad motor coupling, this models equivelent of a belt, you can search you tube for a video as to how to replace it not that bad, seacrh "kenmore motor coupling"
Jan 25, 2009 | Washing Machines
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
55 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
