Question about Samsung CLP 300 Laser Printer
I need to have printed directions for changing toner. I was able to follow the diagrams on the printer up to the 3rd step. Couldn't understand the res
Zahil gave me excellent help.
Thank you
Diane Whitaker
Posted on May 17, 2009
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
How to change laser printhead
Laser printers do not use a printhead.
When the toner runs out you need to get a new toner cartridge which includes the print drum.
You lift up the cover to reveal the toner cartridge, grab the cartridge and pull it out towards the front of the printer.
Reverse this procedure to insert the new toner cartridge.
Apr 09, 2012 | Brother MFC-8870dw Wireless Multifunction...
How to reset ML1640 printer to print after exhausting introductory toner
I dont really understand the question as when you insert a replacement toner it will inform the printer a new toner has been inserted, however if you are refering to Hardware reseting the page count please find a diagram here http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
May 12, 2011 | Samsung ML-1640 Monochrome Laser Printer
HP 4P band of grey on left side of the printed page. What should be done? change toner?
hi
very simple
Use the following troubleshooting steps to resolve this issue:
  1. The print cartridge is almost empty. Shake the cartridge gently to redistribute the toner, or replace the print cartridge.
  2. The print cartridge may be damaged. Replace the print cartridge.
  3. The printer's internal mirror may be dirty. Lift the print cartridge access cover, remove the brush from the underside of the cover, and clean off the mirror using the brush.
  4. use p/n 92274A for toner replacement
please issue 4 thumbs up
thanks for using FIXYA
Apr 05, 2011 | HP LaserJet 4p Printer
Good day, i have a 4730mfp. it does not print colour correctly, the print out appears faded like the printer is out of toner, even after all toners are changed.
First thing to try is this, please go to control panel on the printer and to aministration menu. Scroll down to troubleshooting and find the PQ troubleshooting option and press ok. This will print a series of test prints. If these prints look OK then likely you have an issue with your driver. If they are faded, the second thing you need to do is check to make sure that your firmware revision is current. On the config page that prints with the pages just printed above, look on the upper left for firmware revision. Current version is 46.300.0. Download from here and install following the instruction in the readme file. Did it print OK before changing cartridges? If you installed remanufactured or 3rd party cartridges, the toner will not always provide the same quality of print.
Mar 16, 2011 | HP Color LaserJet 4730xs MFP Printer
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
No longer printes perfectly horizontal on forms, now left side ok and right side drops down a little
Sounds like toner smear. The causes can be:
1. The weight of your paper exceeds the recommended paper weight for your printer.
2. The inside of your printer needs to be cleaned.
3. The toner cartridge is empty and needs to be replaced.
To correct this problem, try the following steps in order. Between each step, close the printer or make sure it's closed, turn it on, and then print a test page to see if the problem has been corrected.
1. Use only the recommended weight paper for your printer. Samsung recommends the following paper weights: 16 to 24 lb. (60 to 90 g/m2) for the main paper tray with multi-page feeding and 16 to 43 lb. (60 to 163 g/m2) for the manual tray and for the tray with single page feeding.
2. Clean the inside of your machine with a moist cloth to remove any dust or dirt inside. Note: DO NOT spray water directly into the printer. Spray the water on a cloth, and then use the cloth to clean the inside of the printer.
3. Replace the toner cartridge.
Jun 24, 2009 | Samsung ML-2510 Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Samsung CLP 300 Laser Printer Logo
47 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
