Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Magnifico eam3200 series...centre piece jammed
The centre piece(brewing system) inside somehow ended up on tilt....top of piece(looking at it) is tilted to the right and jammed...it seems that the centre bottom piece is extended and i'm unable to access the right side white button(can access the left one)
  • 1 more comment
  • rsvp895 Aug 01, 2008
    I have the same problem with the ESAM3500. Turning it off didn't help. I've contacted customer support.
  • Cameo C Massey
    Cameo C Massey Apr 24, 2014
    This happened to me with my Magnifico ESAM3300 - what worked was to forget about the drip tray, just put the container in that holds the used coffee grinds, shut the door, and turn the machine on. It should reset the infuser and release it all the way down so you can then try the red tabs again and pull it firmly out. I did that, cleaned it all out, put it back in and my machine is working excellent. Mine is 3 1/2 yrs old and never had maintenance, I use it everyday, but clean it about every 2 weeks inside and out. I just saved myself a big repair bill.
  • Cameo C Massey
    This just happened to me. What you can try, is to forget the drip tray, just put the used coffee grinds container back in, shut the door, and turn the machine on. Then it will reset the infuser, and release it all the way down so you can then remove it. Make sure you clean everything in that area really good before putting the infuser back in. Then you should be good to go. My ESAM3300 is 3 1/2 years old. I use it everyday, and just clean it about every 2 weeks. I just saved myself a huge repair bill.
I have a perfecta and found that the mechanism that translates the infused up and down was jammed. I unplugged it and removed the back panel - two phillips screws - then you will see the motor and cog belt -BE SURE UNPLUGGED - I then turned the motor shaft using my index finger against the cog belt and with the access door open I could see the infuser translate down to a park position. I took it through an entire cycle which actually retracted the infuser and actuated the coffee grind sweep arm - there is a horizontal feature that looks like a sideways 'L' that seems to be a reference for the park location - since when the top of the infuser was at this mark the infuser unit could be removed and the infuser was in the compact configuration as described in the user manual. I am getting a general alarm still and would like to know if anyone could point me to an electrical schematic and functional sequence block diagram.
Posted on Feb 12, 2012
    New Friend:
Any idea how you get passed the general alarm? the shop replaced the power board :(
Posted on Oct 03, 2016
    New Friend:
Our machine had a "Generic Alarm" on the display. When I opened the unit I was surprised to see that the infuser unit was gone. I thought "Who would steal our infuser unit??" I was relieved to find that it was still there but was stuck up in the housing. Apparently this is the operating position and the infuser lowers itself to the lower position so you can take it out and clean it.
I went to www.delonghi.com and send an email to their Customer Service Dept. It got returned as undeliverable, so I called the phone # for their superautomatic coffeemakers. The lady was very friendly and we tried a few different solutions but unfortunately none of them worked. They're sending me a box & packing supplies and I'll be shipping it to an appliance store in NY to have it fixed.
Posted on Aug 02, 2008
  • Rob Wilson
    Rob Wilson Apr 15, 2015
    hi. i know it has been a long time. but did you get a answer on your problem with the delonghi coffee machine infuser jamming. mine is stuck now
You must  allow the machine to retract by turning it iff before trying to remove this unit. it is supposed to be tilted.
Posted on Apr 04, 2008
Whirlpool 8100 series Top loader;the centre piece will not operate. so it will not turn or spin. everything else seams ok. It seams like the centre section is somehow disconnected?
hello it sounds like the agitator dogs are bad part # 80040 pop thecenter cap off there is a center bolt holding it down the dogs are inside the agitator these should fix your problem if its the top half not moving. if the bottom isnt moving look at the under side of it when you take it oss see if it is damaged. if its not damaged and the bottom half dont move on agitate it could be the trans. please dont forget to rate my answer thank you.
Jun 08, 2011 | Washing Machines
I removed the black brewing system from inside the coffee machine, in order to clean it. Now I can't put it back in. The little wheel attached to the back wall of the coffee machine doesn't want to fit...
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Oct 23, 2010 | Saeco Spidem Villa
Unit stack
Hi
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Apr 05, 2010 | Solis SCDIG-5000 Coffee Maker, Espresso...
Saeco Incanto Deluxe brewunit jammed
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Unable to get the blade or arbour to tilt to a 45 degree anlge. Will only go to about 43 degrees. Cleaned gear shaft arbour moves on with no success.
First look for a stuck piece of wood in the gear tilt area. The other thing is if you don't tilt it that often the track or swivel can get rusty at the ends. try wd-40 on all the moving parts and you may even have to steel wool the track a little... sometimes as the blade tilts a loose screw will allow it to fall out of alignment jamming the arbor. Turn it upside down with the blade fully retracted and unplugged and see if you can give it a push inside as you tern.-- good luck
Dec 09, 2009 | Measuring Tools & Sensors
Magic deluxe does not have enough power
Hi
There are a couple of things you can check. Make sure that the dosing lever is not all the way to full charge. 1 click back from full is the best for strong drinks. Make sure that the grind is not too coarse as this takes up more space and is hard to compress. Check the brew units guides inside the sides of the brew unit. They can be clogged with coffee especially at the top by the brew head. Use a Q tip and clean the guides, they don't need to be lubed. And last the brew unit needs to be lubricated where the O-rings and seals are but only there. The big O-ring on the brew head. Inside the receiver tube on the back side of the brew unit (lube inside the piece top to bottom. And finally turn the brew unit upside down.
There is a rd with a wishbone looking thing in the end of the rod. Lube the rod towards the center of the brew unit. This will lube the seal in the brew chamber. Try these suggestions and see if they don't help?
Oct 07, 2009 | Saeco Magic De Luxe Espresso Machine
How to scan
start from top  look from left to right until reached centre of book when reached centre return to leftside tilt head down 1degree then repeat until end of page at end of page tilt head back to start position turn head to page on right side and repeat process
Apr 19, 2009 | Epson Office Equipment & Supplies
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Gaggia Synchrony Brew Unit Block
You have got the gears out of alignment. You don't really want to take out brew group unless at end of cycle. You can fool machine to get brew group back in.
Here is how :
BREW GROUP REMOVAL AND DRIVE GEARS ADJUSTMENT
FOR AUTOMATIC MACHINES
If you ever find yourself in need of removing a Brew Group that has jammed. This will assist you in doing so correctly.
To fix this problem follow these simple steps:
You will need a #1 Philips screwdriver
1.) First, open the door on the machine and remove the drip tray and dredge drawer
2.) Locate the nickel size hole in the brew group. It will have an "N" next to it. At the 9 o'clock position, you will see another hole about 1/3 of the size of the first. Directly behind this hole, or about an inch up depending on the position the machine was stopped in you will see a single philips head screw. You may have to look around the side of the brew group to locate the screw as it is not always visible from the smaller hole. Remove this screw; it holds a small coupling water inlet (it is similar looking to a tobacco pipe) to the brew group.
3.) Remove the brew group by pressing/pushing (depending on your machine) on the part that says “Press" or "Push”. Pull firmly and straight out. Be cautious to not break the brew unit. Also be aware of the door of your machine as it can break as well.
4.) With the brew group out, remove the small coupling water inlet (tobacco pipe) that is probably still stuck to your machine and reinstall it in the brew group as it was before. Make sure the screw is installed snugly but not too tight.
5.) Turn the brew group around so you are facing the back. Now imagine what a check mark looks like, the top we will call position A (longer part of the checkmark) and where the checkmark ends (the smaller portion) is point B. You will notice what looks like a large checkmark where the coupling water inlet is located. The water coupling can slide up and down in this checkmark opening. The water coupling should be in the B position.
REINSTALLING THE BREW GROUP
To do this, the gears will have to be reset to the start position. In order to do so, you will have to bypass the three micro-switches (Brew Group, Dump Box and the Door switch).
Bypassing the micro switches:
1.) Looking at the back-side of the brew group, not the side that says "Push" or "Press," you will notice something fin-like or nose shaped. This piece fits into a keyhole or coin slot looking slot in the machine and that is where the brew unit micro-switch is located. Take something like an index card, envelope, or folded up piece of paper, and insert it into that keyhole so that it will trick the machine into thinking that the brew unit is installed. Start the piece of paper at the top of the slot and slide it to the bottom of the slot. The paper should be thick enough so you can let go and it will remain in place. Leave this object in there until the following steps are complete.
2.) WITHOUT putting the brew group back into the machine, reinstall the drip-tray and dredge drawer and close the door.
3.) After doing so you can then turn the machine ON. At this time the gears will begin moving until they return to the correct start position. At this point remove the object from the keyhole position and you can now reinstall the brew group. If the brew group does not go back in correctly, try a few more times. The machine will return to its home position. Note: The two large spokes of The brew drive shaft should in the Up position
At times, the gears in the brew drive assembly will not complete the cycle to the proper
start position for different reasons. Some of the reasons are:
• Brew group jammed or blocked
• Either one of the micro switches in the brew drive have gone bad.
• Brew drive motor Failure.
• Broken teeth on either of the brew drive gears.
• Dirty brew group, covered by coffee grinds.
• Brew group or gears not lubricated.
• Connections to the board from brew drive assy., or motor have gone bad.
A jammed or blocked brew group happens when the brew group starts the cycle but doesn’t finish it.
Dec 21, 2008 | Gaggia Super Automatic Espresso Machine...
Brewing System stuck
Hi, I think this is something I encountered once. Try this:
1. Shut the service door
2. unplug the machine, wait for any of the shut down noises to stop
3. plug the machine back in, wait for any noises to stop
4. check to see if everything is back in order
The most important thing is to keep the service door shut, and all the parts, ground basket, drip tray etc. in place. The mechanical will only operate with these things in place.
Hope this helps.
Aug 01, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
2,621 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
