Question about Acer Aspire One Netbook 8.9" Notebook
No Acess to Acer Aspire One
Can't start up my new Acer Aspire One...
can't start up my new Acer Aspire One (mini) even on the battery or AC mode. Only the little red battery light comes blinks on and off.
    Problem Solver:
  • 13 Answers
What little red light is on? Oh, let it charge up first. That light should be green. Hope that helps.
Posted on May 18, 2009
How do i turn off safemode on my acer aspire 5332 tryed rebooting but that hasnt worked. its even disabled my internet acess
You can't turn off safe mode, it means a serious problem has occured in the software of the operating system. In most cases this fix will require you reload the operating system using the recovery disks you either made when the computer was new or you can buy them from the parts dept of the manufacturer.
Feb 07, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
Hi I have a acer aspire 1694WLMi laptop which doesn't charge fully. Also when the ac adapter is connected the screen keeps flashing between battery mode and ac mode.
The source of the problem obviously is either the AC power cord or the battery, or it could be a combination of the two. In terms of the symptoms you describe, it could be a faulty AC cord. This could involve a few possiblities: loose connection between the AC plug and the AC adapter unit, a loose connection between the mini plug (the part that goes into your laptop) and the AC adapter unit, or the AC unit itself could be going bad.
Not sure how intermittent the flashing between battery and ac mode is. If you're talking very frequent such as once every minute or so, I would be suspicious of either the plug (both AC and input to laptop sides) or the connections between the AC adapter portion and the plug. Not sure how long you've had the laptop and cord, but it is possible that the cord has somehow worn out. This wearing out can be accelerated if you often use the AC cord and there is tension on it.
One finally suggestion of course is to either try a new cord. You can often find them on e-bay and can even purchase used ones for a cheap price. If you do, you will then obviously be able to confirm that the cord was the problem. One might think or say the battery is not charging fully and is the problem. True, the battery may be a problem, but the root cause may be the cord.
I Fix It
Aug 14, 2009 | Computers & Internet
How can I unlock the keyboard and mouse on a acer aspire 300
Try starting the computer in safe mode by pressing the F8 key repeatedly on boot. The start up menu will appear. Chosse safe mode and run an antivirus and antispyware program in safe mode. Your system is freezing and that is why your keyboard is not working. You should find that the keyboard and mouse will work properly while you are in safe mode. I suspect that something is stealing your available resources when you start in regular mode.
Aug 02, 2009 | Acer Aspire 4315 Notebook
Can't start up my new Acer Aspire One (mini) even on the battery or AC mode. Only the little red battery light comes on....
If it is brand new, then you have warranty, I suggest you return it to the supplier to get it fixed, because if you do something to it you might void your warranty.
May 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 3680 - new out of box won't boot
NEED TO DEL PARTIONS MAKE NEW ONES FORMATT THE HD THEN INSTALL XP AGAIN AND UPDATE
Jan 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
297 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
