Question about Toro Garden
Toro Weedeater model 51932 will start however won't stay on
Have a 1 1/2 old Toro 51932 Weedeater that recently stopped running after immediately turning on. Is the weedeater at the end of its life or can this be repaired?
  • jpfriden Jul 17, 2010
    I am having a similar problem with my Toro 51932 however it will stay running when I tilt it to the left (fuel cap facing the ground). When I tilt it back to 'normal' position to start trimming it seems to choke out and stop running within 5-10 seconds.
    Any thoughts or ideas would be much appreciated.
    Thank you.
    Thank you.
  • 9 Answers
SOURCE: My weedeater won't run in 'run'.
Sounds like the carburetor needs adjusting. The owners manual should show you how to adjust the carburetor. If not, I would take this to the place of purchase and ask them to repair or replace it.
It should be under warranty for at least 2 years. I have had the same problem and when the carb would not adjust to run properly. I took it back and got a new one . This was at lowes and they were really great about it. If you decide to return it, clean it up real good.
In california we have different regs on outdoor power equipment and can adjust the idle only. The carbs are different for the rest of the US.
They can usually be adjusted, If not take it back. You deserve to get what you pay for without problems like this.
Posted on Jun 14, 2009
  • 376 Answers
SOURCE: weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Posted on Jun 22, 2009
  • 143 Answers
SOURCE: weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Posted on Sep 06, 2009
  • 53 Answers
SOURCE: weedeater starts and immediately shuts off
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
Posted on May 06, 2010
  • 47 Answers
SOURCE: Weedeater starts strong , briefly runs and completely stops.
If it is not REEKING of unburned gas, likely the idle circuit in the carb is fine, but your high-speed jet/pintle seat is caked with crud...
If it was stored with fuel in it, you are going to find that nothing short of a rebuild on the carb is going to help you. :( Luckily, if you are handy many of these smaller diaphragm type carbs can be rebuild with tweezers, slot screw drivers, needle-nosed pliers, can of spray carb cleaner and a rebuild kit from any hardware shop. All told you're going to at most spend $16 bucks. If the engine is otherwise sound with all the work you put into replacing lines, fuel pickup/filer/stainer, the carburetor rebuild route will perk it right up. Good luck!
Posted on May 09, 2010
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
Toro recycler mower won't stay running
take apart the carb float and clean it out, then take apart the rest of the carb and spray cleaner through it. sounds like you might have some old gas turned to jelly in your carb thats plugging it too much for the typical pressures inside the carb to **** through
Jan 25, 2012 | Toro Power Lawn Mower
Toro model #51932 won't idle, runs fine above idle
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ==
Jan 09, 2012 | Toro Garden
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
2,159 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
