Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't start and we're getting the symbols ''F'' and ''dL''
  • 6,784 Answers
Hi, this (F-dL), is a code that represents a failed door locking mechanism. you will have to check the wires leading from the control board to the door lock mech. test with a Ohm meter for resistance. if you pick up ant readings and, the door lock isn't functioning, it is time to replace this device.
In most cases, you will have to replace the door locking mech.
Posted on May 17, 2009
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Dl and F flash when I'm trying to start the cycle...
sorry for the delay in getting back to you. you have a bad door latch mechanism on your washer that needs to be replaced.
Dec 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer error code dlf
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Dec 01, 2011 | Kenmore Elite 45986 Front Load Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Washer won't start, dl signal appears
Your unit does not see the door lock circuit, check the door to see is tabs are broken or missing. If you don't see anything broken or missing, replace the door lock. Part number 34001011
Door Lock
You can order this or go to your local part house and get this part you need.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 14, 2011 | Maytag MAH2400A Front Load Washer
The DL error just came on. Is there something specific we need to do to fix this? It has been working fine, but then all the sudden the error started. Upon initial machine start, it works fine, but then if...
Presumably it is still under guarantee/warantee? You should contact the washer's service department before doing anything else as 'DL' does stand for Door Lock (error).
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor needing an engineer's attention ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | LG WM2277H Front Load Washer
F dl symbol - my door is now locked as well
HOLD THE CANCEL BUTTON FOR 10 SECONDS IF DOESNT WORK UNPLUG WASHER FOR 30 SECONDS PLUG BACK IN SHOULD RESET THE WASHER AND UNLOCK
Apr 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
167 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
